HAF 922 ICE Version !!!!!
jjsky5000
After weeks of designing, and planning i am ready to unveil Blood Ice HAF 922. I had a couple of projects that i was working and wasnt sure i had the time for another. The system with feature a Red & White Theme incased in a Icy Shell.
2011 Cooler Master Case Mod Entry
Cooler Master Vote Page
I would like to thank my sponsors for contributing to the Build
Intel
Sapphire
BioStar
Part List
Cooler Master HAF 922
Intel i5-2500 k
Sapphire 6970 GPU
Biostar MB
Phoybia 4 120mm Silent Fans red/clear
First off was to clean I dust off HAF 922 it has been sitting in a box for about 8 months then onto
disassmebly and strip the old paint from the system, which i was long and very time consuming.
Now that i have it clean enough to piant, I started riviting it back together a added the new wheels to It
primed and painted!! 4 days!!! lol
A few red pieces
Ok back to the unique & by far hardest part of the mod, Moldings very risky!!!!
front panel
dremeled to lay very flat
I have a idea for the front grill
after a day of drying
Molds are ready
Up next a custom side panel i ran out of polyurethane mold supplies, so i had to think of something else i had on hand, Resin perfect.
The HAF 922 side panel sumerged in resin
a sign of curing
Came out better than exspected
Ok I began updating the pc to more the finished product that i had envisioned. First up took off the rollers and add some cool case feet.
Oh getting excited to see it match up with the red inside the case.
Next up adding a window to teh side of the case
added a little ecting With a chilling look
Up next adding water cooling blocks to the components ( converted my 1366 Danger den water block to fit 1156 sockets)
Asus Maximus Gene III and a HD5970
Thats all for now
Ok a good nite of progress added the ROG logo to the front panel fan intake. Came out better than expected
Finished up the ROG logo illumination on the side panel
a few areas to fix but came out pretty good
Installed MB VGA and began tubing fore the water cooling
Thanks again cant wait to put it all back together.
Finished the loop
Did some sleeving !!!! yeh
leak test yea of course it leaked (lol)
running very smooth now
teaser pic
Thanks for looking !!!!
Very nice work throughout the process of this mod.
Another Small update!!!! I had some left over cured resin that game me a great idea
Started on the Asus ROG logo On the side panel!!!!
over to the saw!!
plain old Side panel
3D logo
Some more sleeving to the top panel
Teaser pic
Thank you for Looking
How did you get the ROG logo to light up in two different colors? Did you use two panes of material? Please let us know the secret :D
