Chipset will most likely be fine, CPU also (although you might need 10.6.3 installer to start with IIRC). What's the GFX? nVidia is preferrable, but for example 5770 works great in Snow Leopard. Some motherboard peripherals might also be affected - Soundcards are a bit of a pain but there are hacks, some NICs need additional drivers... It's easily doable if you give it time.
Just a hint from personal experience - Clover saves you a lot of headaches (in most cases you don't need to worry about DSDT...) even though it might be hard to configure from the offset. Happy hackintoshing.![]()
Thanks.
All Im trying to do is recover some data from the HDD on my daughters older MBP.
I was hoping to load an OS on a blank HDD and see if I could resurrect the data.
The MBP wont boot up.
