- Feb 8, 2005
I've got two basically identical ESXi hosts, each with an I350T4 NIC in them. Is it possible to give each VM a port on the NIC and still have the VMs swap over to the remaining host when one goes down? If I understand correctly, passing through the NIC ruins any sort of failover for the VM. What if I created a "Virtual Machine" connection and associated it with a single port on the NIC? Would that work if I were to pull the plug on the host? Should I create a new connection, add all four ports to it, and let ESXi sort out the pathing?
Basically, how should I set up my physical and virtual networks to take advantage of every feature ESXi offers?
