What clocks are you currently at on the HD 7950. also can you bench at extreme settings and post scores.
This is the second 7950 i had, the first one was a Sapphire 7950 Ghz edition not the Vapor-X, the card was faulty, problematic and they changed it to the card that i wanned The Vapor-X 7950 OC Boost
Benchmark & Overclock:
From 950/1200 Mhz to 1100/1375 Mhz, without changing the voltage(is it good?)
Max temp 65 with speed fan at 56%, Vram temp max 68
Asic quality 88.9%
http://tinypic.com/view.php?pic=25pn8mr&s=6
New PR for 3dMark11.
Sapphire HD7950 950mhz Edition
1325/1800
3770k 4.8GHZ
P12,113
http://www.3dmark.com/3dm11/5047572
1325/1800
3770k 4.8GHZ
P12,113
Wow --- that is very nice!![]()
1. Click on "settings" in the bottom right corner after MSI Afterburner is started up. ( It's not hard to find.)
2. After clicking on "Settings" go down to "Safety properties" and select "Unlock Voltage Control" and "Unlock Voltage Monitoring".
There you go!!! I also recommend changing the fan control option to manual while in the settings menu. Might as well have the fan on full blast while attempting a voltage OC, mainly for safety precautions.
Taken long ago, from a forum far, far away. . .
And to enable higher voltages:
https://bitcointalk.org/index.php?topic=18102.0
What programs are you guys using to do the overclocking?
TRIXX 4.4.0b-MOD Smooth like butter.
Time for some 5GHZ Delidded 3770k benchmarking. First time I have ever ran 3dMark11 in Xtreme Mode
http://www.3dmark.com/3dm11/5070771
one question. Core voltage set to 1.2v in Afterburner or Trixx (mod version) and Gpu-z shows arround 1.15v. Which one is closer to real ?
So...what im thinking is there really is no way to add any form of LLC to a video card to stop the vdrop from happening....of course im speculating here
is 1100mhz enough to play top games on full details ? my card is rather far from decent (asic 58%) and when i set 1150 i must bump core voltage arround 1,22v-1,23v (1,18v reading in gpu-z) meanwhile on 1100mhz is running on 1,16v (1,11 reading in gpu-z). In both case temps are ok (below 70c vrm and below 65c gpu in heaven 3.0 couple loops) but dont want to decrease lifetime my card
oh, cant get more than 1450mhz on mems (on stock voltage but dont want to overvoltage it)
Thanks.
That 3dMark link I posted with my score is majorly screwed up.
I'm running an MSI Z77 Mpower MB NOT and ASUS MB.
I didn't use any Lucid MVP software. The CPU speed is way off as well as GPU speed. Not sure what is happening at Futuremark but their online score uploading is screwed up.
Tried OCing my MSI 7950, ASIC 91.6%. Have no interest in anything extreme, just want to be stable at stock voltages. In CCC brought the core to 1000 Mhz, memory to 1575 Mhz. Passed 2+ hours of Heaven without any freezes/crashes/artifacting, temps looked very good in 3dmark11, furmark, occt, etc.
Normally leave the PC on 24/7, wake up one morning and the screen has completely grayed out like something crashed. Reboot and it's fine. Within a couple days, I started noticing hard locks on WoW of all things, even when there's nothing overly crazy happening on screen. Reset clocks to stock in CCC, it's now been fine for 2-3 weeks without a lock/crash/etc.
Would brining the power control slider up to 20% do me any good / stabilize that? I'm not exactly clear on what it does...
Any other ideas? I'm assuming dropping memory to ~1500 mhz would be next?
EDIT: Running i5-2500k @ 4.2Ghz (100% stable since Feb 2012 with a 560ti 448), PSU is a Corsair HX650.
simple solution. Up the volts. My girlfriend has one as well. Came at 1031v at 880mhz. I needed to up the volts to around 1125 to get 1000-1050mhz stable.
Memory I had maxed out with no issues.
Up the GPU volts.
I finally broke X4000 on 3dMark11.
http://www.3dmark.com/3dm11/5126103
No virtual crap installed on system. Not sure why furutremark thinks I'm using it.
