- Feb 1, 2005
What are you guys seeing on the OC with the 6 cores? What settings are you using?
I'm at 4.2Ghz and am stable with Prime95, but I was reading on some websites that they were having a hard time getting to 4Ghz. I am totally new to the Core i series OCing and I've been trying to figure out all the terminology, but anyway, here's what I have:
Cooling: Corsair H50 (single fan since two fans didn't fit with the cooler on the motherboard)
CPU Voltage: 1.325V
Memory Voltage: 1.6V
Turbo Mode: Disabled
Hyperthreading: Enabled
Bclk: 175mhz
Multiplier: Stock x24
QPI: 6.3Ghz (CPU-Z reports 3.15Ghz, but Bios says 6.3...not sure what's going on here)
Memory Speed: 1400mhz (1600mhz sticks)
Some of the temps get a little high in Prime95...like in the 80C range. Is that normal? I came from a X6 1090T and temps above 60C were considered too high.
CPU Voltage: 1.325V
Bclk: 175mhz
