Guild Wars 2 FPS comparison (from their QA dept)
evilsofa
Bill Freist, from the Quality Assurance department of ArenaNet, has posted about the performance they see users getting on Guild Wars 2 during recent stress tests after a lot of optimization was done:
https://www.guildwars2.com/en/news/bill-freist-talks-optimization-and-performance/
The larger chart on the bottom of the article shows FPS from systems with an i5 Intel CPU or better. No mention is made of resolution or settings, but the chart is labeled "Average Framerate by GPU (Auto-Detect)", suggesting it's a quick test done at the same resolution and settings on all systems.
There's also no mention of how large the sample size is, but it's probably quite large, and it's interesting to see how a lot of older cards compare to a lot of newer cards on the same test.
The 7950 matches the 680 wow. The new nvidia driver better be good, the 305.67 didn't feel any different when I tried it last night.
If you're using a GTX 670 like your sig says, then it wouldn't; the 305.67 was for adding 660Ti compatibility and probably didn't give any improvements to other cards.
Am I reading that chart wrong or is he saying that the 301.42 makes a 580 GTX perform the same as a 460 GTX? That doesn't make sense.
How could two cards from the same generation perform exactly the same when the 580 is twice as fast. I have never seen that before.
They're showing that at some point, they found an issue that caused GW2 to perform worse on the Nvidia 301.42 drivers than any of the other recent Nvidia driver versions. They evidently fixed it on GW2's end, because you'll notice the data in the second chart matches exactly the blue bars in the first chart.
I notice in the second chart they don't even have a 580 GTX listed.
It's like they used a 580m to show the framerates with 301.42. Then used a 580 GTX when they showed the difference between the 301.42 and all other drivers.
That would make sense since the 580m performs similar to a 460 GTX.
I seriously hope they fix it so that the next nvidia drivers I can max out the graphics on the game and maintain a steady 60fps+
In all the beta's had to tone down some settings to get above 60fps constantly.
No. You are completely confused. Get some sleep and try again later.
hehehe I read the title as Guild Wars: 2 fps as 2 frames per second.
article doesn't mention what's the resolution or did I miss it?
it doesnt say the resolution no, i looked for a bit. pretty sure 1080p though would be my guess since that is the most common
Bah I'm at work and can't see the link :(
I didn't have any issues with my 470 at 1080p, hopefully my 660Ti has none as well.
Look's like GW2 slightly favors the 7970 over the 680.
