Very nice, though, most GTX 970's can reach 1500/8Ghz mem yeah?
I'll have to pull the backplate to see if its Hynix or Samsung ram on this limited edition card.. high hopes. Thanks all!
when is the 970 successor out?
At this point, the AMD 390/x is so close to dropping... i'd honestly hold for a bit.
Otherwise, if you got the need for speed.....that 970 will do ya just fine. it's a decent upgrade over the 7970/280X for 2K stuff, but the 290 is really the far better bang for buck here. Your average aftermarket cooled 290 is not that much slower than a 970 (stock clocks for both, of course) while being a good $100+ cheaper. Plenty of nice cooling solutions from AIBs out there, so no throttling / overheating etc. In the end, if you want to buy a card right now and want max bang-for-the-buck...go with the 290. With your 280X figured in, you likely would pay ~$150 max for BNIB (290). If you went Fleabay, you would likely spend <$100.
Bear in mind that no current card is honestly comfortable @ 4K, and this is where the 390/X patience may come in to play...
Which card did you get the MSI 100ME?
It seems the driver forces 970 to use 3.5gb instead of 4gb, see the link below.
970 is not an honest product, but while referring to high P/C, it's still a good choice.
https://www.youtube.com/watch?v=qgObJcJhKoc
So would a 970 be a big upgrade from a 670 2gb? 1080p for now. Thinking about making the jump. Got the 16gb ram if it helps iron out any stutters.
Yep, 670 -> 970 is a good upgrade but perhaps just a tad bit overkill if you're still @ 1080P. From those benches, i imagine the 670 still does well enough provided it isn't running out of ram.
I mean, you need a new 2K monitor for that shiny 970 too, right?![]()
Not a bad idea. Been tempted by several of those 27" IPS 1440p monitor deals that keep popping up.
But I guess my thought is with new games coming out like GTA V, I just wanna be able to keep gfx detail up and frame rate enjoyable.
I'm kinda an eye-candy whore ...
I am looking to purchase a 290, but then I noticed that the 290 works with DX 11.2, whereas the 970 works with DX 12.
Any comments ?
