GTX580 pic
nest2001
Lower TDP than GTX480.
http://we.pcinlife.com/thread-1540808-1-1.html
YOU can notice it's different from 480 pcb.
UPDATE: It will PROBABLY be released on November 11.
hope to help
Regards,
nest2001
LOL I'm loving those chinese man, gotta love all the leaks from both sides. This card looks... Generic. The picture of the PCB is a 480 pic as I can't make it out 100% but I can kinda see GF100 not GF110 on the GPU. You didn't post that one probably because of that. The pics here are so generic they could be either card. I'll use google translate to post the TDP.
How funny would it be if they lower the TDP to match AMD 69xx series. (which is higher than the 58xx series)
TDP = 250W GTX 580
TDP = 255W HD5970
:eek:
The last line looks a little bigger and bolder I can see(if I squint) GF100 not GF110
480 PCB no? Note no fan cutouts on the pics posted;
This seems to be it;
Looks good though, no heatpipes sticking out. As we don't have a top pic, I can only hope it's 100% external exhaust. Also, no backplate :( Bring back the backplates!
sign me up for 3 of these if they come with panda pics superimposed on the pcb.
Posted via [H] Mobile Device
So what are we looking at here, $500 a card? Trying to do my IT budget for this quarter and if the numbers look right I'll be getting three.
Since their competition is AMD I'd say $450 max, but it might be a good idea to budget $550-ish "just in case" there is a shortage like the 480s.
Nice pics added in original post by the op in an edit. Not sure if everyone caught them.
Doesn't look to convincing to me. But we'll wait and see if this is a legit picture or not, because most of these Chinese sources are not accurate most of the time.
i like the cooler, it looks like the fan is recessed allowing it the first card to breathe properly when a second is used for SLI.
Could someone find a good pic of a 480 to compare to this? Anyone with waterblocks on their 480 is waiting to see if they'll be compatible with 580...
question here. Even with improved design, are we to expect to need a nuclear reactor to still power the damned thing?
Excellent. The PCB holes and chip placement look EXACTLY the same on the 580 than on the 480. 480 waterblocks (and backplates) should fit fine.
GTX 480:
fullimage.php
I don't even know why you guys bother posting this garbage.
We'll find out the real scoop when it's officially announced...
The 'Little Tiger' pcb is not the same pcb as the 'GTX580' pcb
- the hole are different
- the LittleTiger pcb has 2x 8-pin Power connectors
- ergo, different pcb
As far as I can tell both the screw hole placement and Power Connectors are exactly the same. The only diff I see on the 480 is the fan cut-out and some of the PWM placement.
Yeah, seems strange that a card with supposedly lower TDP would go from an 8+6 to an 8+8 power config.
suppose to be 11inch long and 30% faster in benchmarks vs. 480 but about 20% faster in games
