won't be quiet with a 22watt fan, don't know about the thicker fin's, but we will see if this design works, Nvidia seems to think so and they usually come out with some sick HSF designs.
Are you sure the person who took it apart didn't misread the wattage?
This Delta 120mm x 38mm 120 CFM fan moves more air than most PC cases, and it "only" uses 0.7A, or 8.4w.
The typical medium-speed (~1500rpm) 120mm x 25mm case fan uses around 2.5w.
I'm willing to bet the original article has a mistake, and someone missed a decimal point. It is far more likely that the fan consumes 2.2w, instead of 22w. A 22w fan would be on the order of a room cooling fan, and you certainly cannot move that kind of air through that tiny video card heatsink.
That card is without a doubt the best physically appealing video card I've ever seen. If performance matches I may just buy one.
Posted via [H] Mobile Device
Found them else where. Enjoy.
Except you are comparing a much smaller fan to a 120mm fan. Smaller fans need to spin faster to move the same amount of air. 22w does sound rather high, though, lol.
I take it back. After some thorough searching, I've found some 80mm and 92mm fans rated well over 20w. I seem to remember them consuming a lot less, but then the fastest 80mm fan I ever bought was just around 50 CFM. There seems to be be a huge decrease in performance/watt above that 50 CFM line, as most of the power goes to noise.
This 92mm monster uses 37w to deliver 175CFM:
http://www.frozencpu.com/products/7...er_High-Speed_Fan_-_17503_CFM_PFB0912DHE.html
If that 22w number is right, the fan on this card should be a screamer.
Its too bad AIBs will make it look like shit with their terrible decals.
one thing i cannot for the life of me understand....and it doesnt matter if its nvidia or ati. they are both the same in this matter. why the hell don;t they make the fan bigger. they have the room. or have 2 at lower rpm like the good aftermarkets have? they could almost double the fan blade size and triple the intake ducts very easily. this would work well for all cards....
with FIVE seperate DIRECT touch heat pipes? this thing should do better then most, and probably better then the A/C heat sinks.
When the temperature starts going up in the summer, it is nice not to be baked out of your room due to a hot video card.Why does everyone bitch about the power consumption? Since when has that been a consideration for the high end? Okay, AMDs product uses a lot less... AND? You don't buy the fastest VC to help save the planet.
Is that just a really big heatspreader? How big is the actual chip underneath? Compare to a 5870 which has the exposed chip.
Oh. So we want the fastest VC but more importantly we don't want to get hot or turn up the A/C. Got it.
If it hasn't been a consideration for you, why would that mean it can't be for someone else? Personally I'd certainly rather take a card that consumes noticeably less power even if it was slightly slower.Why does everyone bitch about the power consumption? Since when has that been a consideration for the high end? Okay, AMDs product uses a lot less... AND? You don't buy the fastest VC to help save the planet.
You can CF 5870s on a 600W PSU, that is not possible with Fermi.
Looking at your system specs, you will have to upgrade your PSU if you wanted to install a second Fermi card.
Having to upgrade your PSU adds to the overall cost of buying Fermi cards to run SLI.
It's more than heat, money plays a big role. Most people don't own 850W+ PSUs so Fermi in SLI is not an option, but with ATI CF it is!
ATI can run 5970s in CF on a 850W PSU, but Nivida can only run two GTX 480s in SLI on the same PSU. Which is better and more high end?
You still can't compare a 120mm axial fan with tons of fin surface area and slow rotations to a two inch squirrel cage blower fan with less surface area than half of a single fin on a 120mm fan. A blower fan that probably has to spin @ 4000 RPM to push air sideways at enough pressure to push through such densly packed fins and out the other end of the videocard. Completely different tech but it is going to be noisy.
