Ensign.Fodder
- Sep 1, 2005
So I have been out of commission for about two weeks (dead PSU & family medical crisis) and just recently got my system up and running again so I am not sure what the "cause" or "when" the problem happened but:
Using MSI Afterburner to OC I see the first GPU scale up clock when folding on that card
I do not see the same on second but GPU usage is 99%
1st is 875/1750/1800 (core/shader/memory) and settings should be synchronized
2nd is 405/810/1800 (confirmed with GPU-Z)
Currently both are connected to a monitor (DVI & HDMI to same)
Physical SLI bridge is installed
SLI is disabled in nVidia control panel
New PSU is a Thermaltake ToughPower XT 750 replacing Coolermaster GX Series 750.
If I run FurMark 1.9.1 (after enabling SLI) I see both cards at OC max and UPS starts screaming since draw is higher then maximum.
If I run F@H with SLI on I see both cards hit maximums but I always thought I needed to have SLI disabled?
Any ideas?
Any ideas?
