GTX 690 owner's experience
Good news gents! A GTX 690 is en route to me, can't wait to see what the sucker can do :) I'm crossing my fingers that I can OC to at least 1190 while maintaining less than 70C (to prevent throttling), and hopefully I can OC the bejezus out of the memory as well.
Bad news? I have 3 GTX 680s sitting here, going up on ebay tonight. Well, the 2 EVGA 2gb ones for sure, I definitely like the 4gb galaxy 680oc though - might hold onto that one for another build. Anyway, I haven't been this exited about new PC hardware in a while.
You'll be able to hit 1190 without 70C assuming you're computer isn't sitting in the desert.
I sure hope so. The airflow in my case is pretty impeccable, yet reference 680s take a beating temp wise when I overclock them past 1250...I have to use manual fan at a high setting and they still can get past 70C in certain games like crysis 2 with everything turned way up.
This is seriously my favorite GPU purchase in a long time...I love this thing. So far i've managed to overclock to a level where my boosts are consistently around 1200 stable, but the differentiator is that my memory OC's to absolutely insane levels. The 690s are using high quality VRAM apparently, my 690 overclocks the VRAM to +600 offset stable for hours. That puts my VRAM speed at 3600mhz so its 7.2ghz GDDR5 effective :eek:
Oh my old EVGA 680 vanilla SKUs the memory would OC slightly but no more than 100 to 150. I think the 690 is using much higher quality VRAM....i'm getting absolute insane memory overclocks and it definitely increases performance in games that are bandwidth starved (crysis 2, metro 2033). I have not found an upper limit on memory OC yet! My old 680s would always artifact without fail if I pushed the memory too high. Not the case here!
I just ran it through the gauntlet of crysis 2 with HD textures, dx11 on, and full motion blur. Did not BSOD, artifact, or TDR....
Did I mention I love this thing? Next project will be putting this bad boy under water.
Hey xoleras, glad you love your 690! Keep us up-to-date on your OC fun.
I have a question. You kept mentioning over 70 deg C the 690 will start throttling. Can you be more specific? What does it throttle? Core/mem frequency? Power? I noticed my GPU temps were over 70 and it was still boosting the cores to1058 MHz which is the highest stock boost I have seen on my 690. I still have everything stock and the fan was only at about 60% so I think the card still seems to be happy over 70.
70C and 80C are throttle targets if you're overclocking. Generally what i've seen is that the GPU's will downclock in 12MHz increments, and your voltage will lower by 20mV increments once you hit 70C, but it sometimes balances back up. When you hit 80C you will definitely downclock nearly always, in 12C increments until the temp balances.
What kind of setup are you running xorelas? One monitor, multi? I ask because I'm on the fence about returning my 680 and going to frys and purchasing a 690( have it on hold ) or saving money and getting two 670s ( also on hold) I only run 2560x1440 . Put me over the fence!
I've heard a few people saying they are going to get two 670's instead of a 690, but the (slightly) higher performance, less power, less heat make the 690 attractive.
Though you can get 4GB versions of the 670's for Surround Gaming as 2GB might not be enough for using AA at those levels
Yea, I'm just trying to justify the purchase is all, I play BF3 but I have to turn HBAO to SSAO with no MSAA at 2560x1440 with my 680 and the frames drop to the low forties sometimes on 64 player maps ( usually stays at 60 though) I can't enable high physx in batman and I get around 48 fps. I did just win $400 so the offset of returning the 680 (+500) would be around 200 bucks.. hrmmmm and 2x 670's would actually only be 860 (las vegas tax) hmmhmhm
Single screen 2560 resolution. Single GPU doesn't cut it at that resolution , there are a few games where (as you saw) that you have to lower detail settings a bit....so I opted for dual GPU.
The 690 has blown me away. There is simply nothing bad to say about it, from noise to performance to bling factor. It is just awesome, if you can get one DO IT! :cool: I'd say, only go for 670 sli if you really need to save the money. Reports indicate that the fan on the reference 670 is a lot louder than the 680, and some of them have coil whine. You can avoid this with aftermarket cooled cards, HOWEVER, using SLI with aftermarket cards is BAD news. I can't begin to tell you how much headache that is, because your top GPU will become a toaster since both cards will dump a ton of heat in the case. So because of this I'd rather have 680s or a 690.
One minor annoyance, do any 680 or 690 owners play WoW? I play WoW with vsync off, fullscreen windowed at 2560 resolution...and apparently the drivers think that I have too much horsepower and constantly downclock the card to lower speeds while i'm playing WoW. Very distracting because I get dips to 40 fps in certain areas due to this. I tried adaptive vsync, same thing....fullscreen mode, same thing.....anyone know how to prevent the throttling in WoW?
Are you using Precision X? Try the frame rate target feature. I haven't tried it but maybe that will work?
I started to notice a weird line when watching Youtube videos; kind of like screen tearing but it runs horizontally somewhere close to 1/3 way from the top of the screen. I'm not sure if this is a driver issue, flash problem, or SLI artifact.
I figured out the issue. Apparently, older games have the vsync stutter issue when you enable vsync in game. Its not a big deal really, it only happens in really old games, so far it only happened in darksiders and WoW.. so right now i'm just disabling vsync and I don't get the random frame rate dips. What was happening before is that I would get random unexplained sudden drops to 20 fps for about 10 seconds in games like WoW, and it ONLY happened when I enabled ingame vsync. If I use a framerate limiter - doesn't happen ever - if I use vsync disabled - doesn't ever happen. Its apparently a big problem in the new drivers, but will be fixed in the next release. Per this thread: http://forums.nvidia.com/index.php?showtopic=226227&st=320
The workaround is easy enough. Don't turn on ingame vsync in old games :)
Anyway, still loving this card. I have my overclock at +150 gpu (works out to 1200-1210 at load per gpu), +500 memory, +120 power target. Stable in everything, I get around 17.2k in 3dmark11. Not shabby! That overclock puts it beyond stock 680s, i'm extremely happy.
With a name like that (with 1's in place of I) I bet you could easily guess his age, not to exceed 12.
Has anyone set up quad-sli with the 690's? Anybody experience scaling issues? Or is this normal?
Unfortunately Hydrasun, I don't think I can see spending another 1k yet on a second 690. I am getting my first one today. I will comment about your possible issues on your other thread.
As for the question earlier about surround setups, I have 3 28" monitors that I will be using with mine and will test that setup pretty thoroughly. I was very upset over AMD's poor support and drivers for Eyefinity, which has driven me to the 690 purchase.
Just got mine Firday :) was busy doing some quick benchies and experimenting with a GTX 550 Ti for dedicated PhysX
I may post some numbers up here after a while to see if I am where I should be performance wise, I went from CFX 6970s and I will say this much... I freaking love this card right now just for the noise levels!!!
Especially compared to two screaming 6970s when gaming! I even tried MSI Afterburner to quiet them down and no luck!
Here is my current problem though... and maybe I can get some opinions here.
I currently have two monitors I can use:
Samsung S23A750D LCD which is a 23" 1920x0180 120Hz monitor that I absolutely love... it is the closest thing to a CRT I have come across in a Desktop LCD. Contrast and colors are good and motion is great....
Shimian 27" IPS 2560x1440 monitor 60 Hz.. The colors and contrast are pretty good on this but not great, motion to me is not as good as the Samsung... but better than some cheaper LCDs I have used.
Both have some pros and cons.... which would you rather use?
I do have two 22" CRT monitors too :D (SGI and a Samsung Syncmaster) beautiful condition and neither of these monitors can compare to them for motion or contrast.... but the size of them on my desktop kills me. Plus since they are 4x3 the lack of width kinda kills it for me.
Out of curiosity anyone with a setup close to mine in my sig? I want to compare some numbers, I don;t think my performance is where it should be, not sure if this is due to some other issue or not, but wanting to make sure.
I think breadman was the closest @ 4.7GHz and I can OC mine to 4.7GHz to match to try and find out.
uggghh.... wish now I had got the Catleap 2560x1440 monitor so I could at least try to o/c the monitor and get it at a higher refresh. But nooooo I had to get the Shimian that you cant do that with :(
The motion is just soooo much smoother on the Samsung, I don't get motion sickness looking at stuff moving and seeing the trails.
Think I am sticking with the Samsung for now.
BTW if anyone wants to see the results of my benchmarking with a GTX 550Ti for dedicated PhysX go to this thread: http://hardforum.com/showthread.php?t=1684699
Same here! I had 6950s flashed to 6970 spec and boy were they loud at times!
I actually got to play some games monday night for an hour straight! WOW :D that's a first in a long time! The fans on the 690 reved up... but still no where near as loud as a single 6970.. NO WHERE NEAR
I get to try it again tonight :D so hopefully I wont be too exhausted tonight and can have some fun!
After being the unfortunate owner of a 9800GX2 and 2 5970's, after owning the 690 for a few months now I can honestly say this is the first multi-gpu card that's worth a damn.
for those who might be watching the thread I posted earlier where I put some results up with a GTX 690 and physX on, then a GTX 690 with a GTX 550Ti dedicated for physX I will be testing out a GTX 480 next for physX in that thread. The 550 has 192 cuda cores, while the 480 has 480 cuda cores....
Anyone attempt to overclock their 690 yet? I am tempted to.... but at the same time since I am sticking with my Samsung 120Hz 1920x1080 monitor for now I seem to have a ll the FPS I need lol.
I tried to stick with the Shimian 27" 2560x1440 monitor.... but the motion was too bad to me, I kept seeing trails behind everything, kinda made me sick after having this 120Hz monitor now for so long. I just wish I could use the 3D functions of the monitor I have but sadly since it is not a 3D Vision monitor... it will not work in frame sequential, only side by side or top / bottom.
If I could see the new Asus 27" 3D Vision 2 monitor in person I would be tempted to get it after a few months.
when i first got this card i was able to play at +140 core +300 memory but now each day i have to keep lowering the memory offset, im all the way down to +100 on the memory but still crashing in BF3, lowering the core clock does not help...is it possible the vram on my 690 is faulty?
*edit
Locking the voltage to 1.175 has had me stable in bf3 for a few hours straight at +155 core and +280 memory seems to have done the trick.
*edit
Yeah, I was going to say it seems more like a voltage issue you are encountering. That is one of the reasons there are more options for offsets and ranges so not only do you set a voltage but you can set a voltage offset for when even more power is needed.
can someone post up some bench marks they did so far? Trying to compare I still don't think I am hitting what I should be with this system. I pulled out the GTX 550 Ti I had in for physX thinking maybe the main PCIe slot the 690 was in was limiting me (when another card is in it goes to x8) but I seen nearly no difference.
I may have to re-format and clean install everything to see if there is something deep in windows leftover from the ATI cards I had causing problems. I removed all drivers and programs and ran ccleaner it doesn't look like there is but something is limiting me here....
Rig specs are in my sig
as for what to run I have a ton....so take your pick. 3DMark11, Metro 2033 built in, Batman Arkham City or Asylum, Just Cause II, Mafia II, etc etc
Mafia II
Settings: Bult in benchmark, 1920x1080, AA On, AF 16x, Shadows High, AO On, Geom High, PhysX OFF
149 fps A
Metro 2033
Settings: Built in becnhmark tool, Frontline. Direct X 11, Resolution: See bench, Qual: Very High, AA AAA, Texture Filt AF 4X,Advance PhysX OFF, DX 11 Tesselation and DOF enabled 1920x1080
Avg: 69.97
Max: 337
Min: 10.14
Batman Arkham City
Settings: Built in Benchmark, Reolution: See Below , FXAA High, DX 11 Feat MVSS and HBAO, DX 11 Tess High, Detail level Very High, Dynamic Shadows Yes, Motion Blur Yes, Distortion Yes, Lens Flares Yes, Light Shafts Yes, Reflections Yes, AO Yes, HW Accel PhysX Off
1920x1080
min: 20
Max: 280
Avg: 157
Unigine Benchmark
Settings: Direct X 11, shaders: high, Tesselation: extreme, Aniso: 16, AA: 8x Full Screen, 1920x1080
FPS: 80.9
Score: 2038
Min 29.9
Max: 197.1
3DMark11 Advance Edition
Extreme benchmark settings:
x5861
graphics score 5607
physics score 10374
combine score 5470
gt1 28.89
gt2 28.77
gt3 27.26
gt4 17.24
pt 32.93
ct 25.44
I've had mine for a few months and love it. Only thing I'm not too happy about is my temps. At stock temps and with Vsync off in games, I get 75c on first core and 72c on the second. This is with no OC. I'm assuming this is because of the air flow in my case? The 500r has two 120mm fans as intakes in the front of the case. The 690 exhausts heat in to the case on one end, and out of the case on the other. I'm assuming the end that is exhausting into my case is running into the air that is coming in from the two 120mm fans?
I'm sure if I switched them around to exhausts, the temps would be a bit better. I'm lazy though, and I get 60 fps on my monitor anyway with ease :)
Yep, I noticed this as well when I was using a 690, it does get warm with vsync off. This is bad because you can't overclock properly when the temps go above 70C.......
Kepler throttle FTL. Its why I switched to MSI lightning 680s, I don't like kepler throttle at all.
For those that own one of these cards, is 1 of them able to handle lets say BF3 with max settings at 7680x1600? If not would 2 of them in quad sli be enough or would it be better to just get three 4gb 670/680 gtx's for Tri-Sli?
I really enjoyed the GTX 690 when I had it, although the kepler throttle is somewhat annoying. That being said, I'd honestly use a 4gb 680/670 for that resolution....despite what some may say, 4gb is helpful in surround and allows you to run higher levels of AA.
