tempuratures have not a lot to do with heat, at least compared to the cooler design and ambient temps.
I meant hight temperatures in the 100 degrees C. Here in California my house ambient temperature is between 70 ~ 80 F. I don't know how hot one of those GPUs would get in my house. Perhaps I'd have to have my AC @ 60 ~ 62 F for the GPU to work cooler.
Temperature is a measure of the average heat or thermal energy of the particles in a substance. Since it is an average measurement, it does not depend on the number of particles in an object. In that sense it does not depend on the size of it. For example, the temperature of a small cup of boiling water is the same as the temperature of a large pot of boiling water. Even if the large pot is much bigger than the cup and has millions and millions more water molecules.
You are not fully understanding this. Temperature and Heat are two different things. Do you want a card that runs at lower temperature or one that produces less heat at load?
All of the cards named in the title do heat up under load, but not extraordinarily so. The 460 and 560 reference designs get up to the low to mid 70 *C range under load, the 570 and 580 get up to the low to mid 80 *C range. They're perfectly fine.
Since you seem to value low heat output, be wary of the 465, 470, and 480. Their coolers do not cope with their heat outputs well, and the GF100 core is not as efficient as GF110 is, so they get pretty hot and noisy under load.
