GTX 570 Build
Nexrus
1) What will you be doing with this PC? Gaming? SW:TOR, D3
$1000 shipped
3) Which country do you live in?
VA - USA
4) What exact parts do you need for that budget?
Case, mobo, cpu, cpu fan, gpu, ram, hd, cd-rom, PS, and Win 7
5) If reusing any parts, what parts will you be reusing?
None
6) Will you be overclocking?
No
22
End of the week
9) What features do you need in a motherboard?
No features in specific, just something that will utilize my hardware to its potential
10) Do you already have a legit and reusable/transferable OS key/license?
No. It will be included in the $1000
Below is what I came up with. I don't need something that will shred any game on the marker. I just want something very reliable that I can play msot mmos on med/full settings.
ASUS DVD Burner
I could care less if it has a burner, as long as its black and matches the case.
Cooler Master Storm Scout
The cable routing is a must
WD Caviler Blue
(capacity is not an issue for me)
ASUS M4A87TD EVO AM3
No real reason for choosing this other than I'm using it in my current build and I'v never had a problem with it.
Eveva GeForce GTX 570
Highly recommended by a friend - I dont have the money to SLI at the moment
Raidmax Hybrid 730W
not wild about the blue neon but I love the modular cables and I'm afraid anything under 700W wouldn't be enough?
CORSAIR Vengeance 4GB
Always heard Corsair was the best ram so I figure Ill give it a shot.
AMD Phenom II
AMD seems to be a better bang for buck overall? Maybe Im wrong.
Zalman 120MM
Had this in a previous build and loved it. Rand quiet and seemed to get the job doen. I am will to downgrade if possible.
Windows 7
What's the max resolution of your monitor?
ASUS DVD Burner
This is not worth the extra $5 once you factor in shipping over this DVD burner:
$20 - Sony AD-7260S-0B SATA DVD Burner
Not a good choice as it has limited cable routing and is relatively cramped for a case of that cost. Take a look at these other cases instead:
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$60 - NZXT Source 210 Elite ATX Case
$70 - Lian Li Lancool PC-K58W ATX Case
$70 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$100 - Lian Li PC-7FN ATX Case
$110 - Lian Li PC-60FN ATX Case
WD Caviler Blue
I understand that space isn't an issue but performance should be: That 320GB drive is slower than this 1TB drive:
$60 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
Wait, is this PC suppose to be for someone else or something? Why else will you be buying the same mobo twice?
Depending on the max resolution of that monitor, that GPU may be stupid overkill or just right.
Raidmax Hybrid 730W
The problem is that you chose a PSU that's not even capable of 500W let alone 730W. So definitely ditch this PSU. Now if you really do want modular cables, this is the cheapest modular PSUs that I can recommend that can still power your system:
$110 - SeaSonic M12II 620 Bronze 620W Modular PSU
$120 - Corsair 650HX 650W Modular PSU
Now if you don't need modular cables, then I recommend this PSU:
$85 - Corsair 650TX V2 650W PSU
Not a good choice at all for the money. An extra $15 gets you twice as much RAM while retaining the same per RAM performance:
$48 - G.Skill Ripjaws F3-10666CL9D-8GBXL 2 x 4GB DDR3 1333 RAM
AMD Phenom II
Unfortunately you are indeed wrong when it comes to this CPU: Even though it costs $20, the Intel Core i5 2400 provides a better bang for the buck than the AMD Phenom II X6 1090T. Greater gaming performance, trailing not too far behind the X6 in video/media encoding/rendering applications, and uses significantly less power and therefore less heat.
Zalman 120MM
Not that great for the money. This Coolermaster HSF actually outcools that Zalman while being quieter and cheaper:
$30 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
$1000 shipped
VA - USA
None
No
22
End of the week
ASUS DVD Burner
WD Caviler Blue
Raidmax Hybrid 730W
AMD Phenom II
Zalman 120MM
Windows 7
I agree with Danny Bui: In fact, I cannot recommend a PSU that cannot deliver its advertised wattage regardless of price. That Raidmax PSU is one of many that can barely deliver two-thirds of their advertised wattage without going way out of spec on the DC output quality.
And even though the 320GB WD Blue is a single "500GB" platter that's been short-stroked to 320GB, the smaller-capacity WD Blue hard drives have had significantly slower access speeds than most other 7200 RPM hard drives. The slower access speeds make that particular Blue less suitable as an OS drive than most of the other 7200 RPM hard drives.
And not all current 22"-class LCD widescreen monitors have a native resolution of 1080p (1920x1080): Some of them that are still on the shelves have a native resolution of only 1680x1050 or (gasp!) 1600x900.
Finally, at that price point AMD's hexa-core CPUs actually underperform Intel's quad-core CPUs in general usage (including gaming). Very few mainstream applications even today can fully utilize even a quad-core CPU, let alone a hexa-core CPU.
First of all I really appreciate the feedback.
I believe its 1080p so 1900xsomething
Yes its for a friend.
Noted. I didn't use a ps calculator, I just assumed I would need around 700w. Could I get by with less?
Only thing different I recommend different is this RAM over the RAM that Danny recommended.
$44.99 - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
He is 100% right though. You will not see any real world performance difference between DDR3 1333 and DDR3 1600, but the 1600 is cheaper right now.
Double check that. It's very important to know what the resolution is as it will determine your GPU choice.
If you're using the GTX 570, I would recommend no.
Based off the info that you guys have given me this is what I have. Since I switched to intel I need a suggestion for a new MB. I've also decided to take your advice and go with a better PS. I'd love to stay with something modular but if its impossible to get with my budget I understand. My budget for both is around $150-170$
Sony DVD Burner
The CD Rom suggested was only available as a combo.
I know you suggested not getting this case but I'm fairly set on it. The black interior is a plus and the noise level is extremely low, from what I've read.
Samsung 1TB
Took your advice and forked out an extra $20 for the better HD
The screen will support 1920x1080
G Skill 8GB
Again, I took your advice on this one.
Intel Core i5
Forked about the extra $20 to get a better processor.
Cooler Master120MM
Recommended and has great reviews
Windows 7
Is there a cheaper place to buy a legit copy?
$150 to $170 each? Or for both items together?
In any case, I've already recommended PSUs to you earlier so read my earlier post again.
As for the mobo, I recommend this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130579
Sony DVD Burner
Must've changed since yesterday. Go with this DVD burner instead:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151233
I know you suggested not getting this case but I'm fairly set on it. The black interior is a plus and the noise level is extremely low, from what I've read.[/QUOTE]
I'm telling you man, it's really really bad purchase, dude.
Go with this different eVGA GTX 570 and Core i5 2400 from this combo link:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.733436
$2 more but you get a lifetime warranty VS a 3 year warranty with the card you chose.
Windows 7
Yes if you're a college student or your friend is a college student.
Just go with a 650- to 750-watt class PSU. Be aware, however, that many of the cheaper PSUs in that advertised wattage range are crappy or even shitty in quality. Good-quality 650W units, especially modular ones, do not come cheap.
I went with the 650watt corsair reccomended. I think that's enough?
