reveille_83
- May 16, 2006
Fellow HardOCPers,
So the last couple weeks have been crappy for me. I'm already on my 2nd GTX 285 video card and am having a little difficulty deciding on what to do.
A little background I recently purchased a BFGTech OFCU GTX 285 Video card and was very pleased with its performance but shortly found out that it suffers from an excessive amount of overheating and would cause instability problems in any games I threw at it. I quickly RMA'd the card and instead of waiting decided to get the XFX Black Edition GTX 285 which I believe is clocked at 690MHz.
- It seems to suffer from the same problems as the BFGTech and others like it. If I jack up the fan speed using RivaTurner it seems to run better, but I'm just not happy that I have to use a program to jack up the fan speed to make it stable.
Are all GTX 285 cards suffering from this problem? What are you guys doing? I thought about getting an aftermarket HSF. Anyone doing this? What are you using?
I thought about RMAing this one as well, but I feel like I'm just going to have the same problems unless I do something else to the video card. (Put a BOXFAN next to my open case, aftermarket HSF, different card, etc)
Is anyone else suffering like I am? What have you done?
Thanks for all your input.
