Need more then that. What resolution are you running at?
yes..it's your cpu, holding you back..big time. I get an average of 45fps (my GPU's are factory overclocked @ 670Mhz)
I would assume that your missing out on around 10+fps just with that CPU.
That CPU is hurting...even if you took that E6600 to 3.8ghz...you still wouldn't be getting the most out of those cards IMO.
With the rig in my sig, I get around 24-30 FPS with everything on Enthusiast and 4xAA. My CPU isn't peaking.
Should I be getting higher frame rates?
Running at 1680x1050.
actually that fps is really good already..
you can't go over that range..
in the Train stage, your FPS will drop deep blow than that, just let you know..
its normal... not cuz your CPU is bottlenecking, its your GPU that is limiting in this point.
btw, you playing on DX10 or DX9?
Matrices said:Your settings are simply way too extreme for the hardware you have. A single GTX 275 and C2D is not enough to run Enthusiast settings even with no AA, never mind 4xAA. Better off trying 2xAA, and probably reducing everything but post-processing to Gamer.
ign.com said:I played Warhead on a high-end machine with a quad core CPU and the latest Nvidia graphics card at high resolution (1680x1050) with all the details set to Enthusiast, which is essentially very high. It looked cutting edge and the frame rate was solid.
DX9
Then what's up with the IGN review when they say:
This review would have been around when the game came out, so my graphics card is undoubtebly better than the one in their post in which they describe.
So I downloaded a program called RAM Monitor. It shows that I've used up 1900MB when the game is full out going. Will it be worth it to upgrade to 2 more 1GB sticks since I'm on a 32-bit OS?
