Hi guys
I'm new here but really desperate so I need some help please.
I had a GTX 260 that was working fine in my machine however I traded this card for a 8800GT (Don't game as much anymore) and gave my friend this card. However once he got and tried to use it he has had no luck. This is how he describes what is going on with the card:
"The card started up fine and then before it had even done it's initial install it stopped... Worked about 2 minutes literally... and now the fan doesn't even spin up when I switch on the machine. Tried various combinations of power connectors and clearing the bios on the mb, with no success."
"It posted and booted to windows, vista started automatically installing a driver and it asked to restart, I did so, it booted back up, into windows, and as I opened a folder from the desktop with a driver in it, the screen just went black with no sound or any kind of artifacting, I restarted the machine and it did an unusual post beep and the screen didn't react to the power coming on. I checked and noticed the fan was not spinning on the card, but is turning freely, and when I initially started up I checked that specifically, it was spinning fine and exhausting air out the case correctly. Since then I have used various combinations of power to the pci connections in case it's a rail problem, but has made no difference. I have left it off and unplugged for half an hour or so and then tried again. I tried removing the card and starting the machine with nothing in the slot, and the post sound is identical to when it is in. Lastly I tried resetting the bios with the mb jumper reset, and still nothing.
The card is a tight fit in the case but it fits fine I think and doesn't seem to be on any of the motherboard components, bar a minor passive heat sink which it may just touch but I don't see being a problem."
He has a Gigabyte P35C - DS3R motherboard and a Omega ISonic 600W PSU (its a local brand, 5V-28A, 3.3V-30A, 12V1-16A, 12V2-17A). Any ideas on what could be wrong and whether can get this working again? Is it the card thats has blown?
Any help will be greatly appreciated.
Thanks
Brendan
Thanks
Brendan
