JustReason
razor1 is my Lover
- Oct 31, 2015
I am very skeptical. There are no numbers on frame rate or any performance numbers for the 1080 pics. Serious Salt Stance taken.
Lol this card is a joke if that is really its performance. It would only be around 50% faster than a 980 based on that which is laughable for going from 28nm to 16nm, using a better architecture, and running much higher speeds.
This thread is full of feminazi's that don't like to speculate, have opninions or want others too. Why don't you all just put this thread on ignore FFS and move on.
If this is true, the scary part is the 1080 is 2560CC compared to a 980ti with 2816 GTX and only being 25% faster. Problem is we don't know if the 1800mhz on the 1080 is overclocked? Or normal?
Thats why I said earlier I would like to see a maxwell 2816CC vs a pascal 2816CC. Same clocks. I want to see if pascal IPC went down a bit or not. Really has me curious.
My guess is that Nvidia is getting every bit of clockspeed they can out of it to try and make up for the lack of IPC..
Not impressed at all, this is like what AMD has been releasing. But that's a win for me because that just means that I can use my card for another year.
I thought we were expecting 20% more than the 980 Ti?
Might be disappointing OC results based on these clock speeds.
Close to the performance of an overclocked 980Ti while being overclocked itself isn't what I think most people expected.I thought we were expecting 20% more than the 980 Ti?
A reference 980 has 2048 cores that run at 1250. This card has 2560 cores running at 1800. That is technically 80% faster if it scaled perfectly still using the same architecture. Instead we are only getting about 50% better performance which would be piss poor even if still using Maxwell but even more ridiculous considering this is a supposedly better architecture.Just out of curiosity, how much faster do you think the 1080 should be over the 980?
which is why im wondering if the IPC is now slower with Pascal.
Tinfoil hat!
Its not, the kingpin overclocked still has boost clocks on the 980ti......
Yeah it ALU vs ALU clock for clock Pascal is around 20% higher with that Firestrike scores.
I don't understand why you guys can't do this math????? pretty easy to do, just multiplication and division.
And how exactly do you know its not? You got the cards in your hand doing a review for us?
Seriously people who say they know stuff about these new cards when its all speculation is just mind boggling.
Do the math. I'm not speculating anymore, and if you want to ask that question, I suggest you look at my history.
PS I haven't been speculating for quite some time now either.
What will you do if this come true? cause I can't get any more specific without divulging things I can't?
Will you apologize to me?
PS things that are already out in the open I can talk about, anything else, well shits and giggles.
No I will totally admit I was wrong. Just like I was totally wrong when the 970 GTX was as fast as a 780ti for $329. I was wrong and admitted to it.
Which is why I own a 970 GTX (I had 2 before the memory fiasco!)
The reason I ask is, the 1080 with lower CC count @ 1800mhz is matching a 980ti @ 1500mhz. It you used the came CC card and put the frequencies of the cards at say 1500mhz I am curious if pascal has faster IPC.
hmm what, where did ya see that, The 1080 was at 1800 (boost clock) another words ~1600 base clock maybe even less well......, the 980 ti with LN was at 1800
oh ok my apologizes, didn't see that, yeah I wouldn't use 3dmark 11 for this kind of test doesn't work too well for these cards. You will run into bottlenecks that will skew the results. Well not skewed the results are valid, just not what would be the best in what today's games or future apps will hold up to.It is from another forum I was reading. Here is the comparison
I scored P18 872 in 3DMark 11 Performance
Close to the same CPU Freq. and the 980ti was boosted to 1500mhz
Lemme find that user, he was on guru3d.com
here: Guru3D.com Forums - View Single Post - First NVIDIA GeForce GTX 1080 3DMark Benchmarks
And probably 99% of games will not be true DX12 games for the next year or so. The DX12 crap we have now is mostly just tacked on features to market it as a DX12 game.I do agree, but we have nothing else to compare the benchmark too. I actually hate 3dmark, but you can have a base to go off of.
For all we know 1080 GTX is a DX12 machine, which 3dmark doesn't show.
Hmmmm. If that holds true, that's a big 'ol "nope" from me. At this point, my next card needs to be a 1-card 4K solution. I've already got 1080p more or less covered with my OC'd 980 GTX.
Still relevant, just not as much as the old days.
3D Mark hasn't been relevant since it stopped using actual game engines. That was a very long time ago. It's scores are arbitrary numbers that do not correlate with game performance in any way. The variables that tend to raise scores in 3D Mark aren't necessarily the same variables that actually improve real world game performance.
It's certainly more accurate a performance metric than any one game...
I mean, given an arbitrary number of games being benchmarked 3DM is a better indicator of overall performance than any single game of the set, which is why it exists imo
the entire point of it is to give a relative view of what performance should be like in comparison to other configurations, same thing as passmark. how you choose to use the results is up to you. i've used results from passmark in order to extrapolate what my performance would be like going from a 2500K to a 4770K in BF4, and they were highly accurate because i understood how to use them.I'm sorry but that's just not the case. 3D Mark isn't an indicator of overall performance because its numbers do not translate into anything meaningful. You can't say a score of 18,000 3D Marks equals 120FPS at 3840x2160 in Crysis 3 or anything so specific. It doesn't reflect performance relative to game engines because it isn't using any game engine. 3D Mark performance can be improved by CPU upgrades or clock speed increases that wouldn't have the same effect in games. Going from 4.4GHz to 4.6GHz for example might give you a significant jump in 3D Mark scores but that increase won't translate into substantial FPS gains.
There are countless examples of this over the years. Throwing in a PhysX card used to add a significant jump in 3D Mark scores even though it did nothing in games that didn't utilize it. Adding more CPU cores (beyond 4 cores) would impact performance even though most games can't leverage more than 4 cores. Adding more clock speed when you are primarily GPU bound improves scores, and lets not forget one of the best examples of all time: AMD's Radeon 2900XT. It was a 3D Mark queen that scored well above that of its NVIDIA counterparts only to perform worse in virtually every single game out at that time or that had ever been made up to that point.
It isn't an accurate performance metric of overall performance because it's far too general. You can say a system that gets x number of 3D Marks is a fast system, but I can look at the system specs or device manager and tell you that. Neither of those things tells you very much. At best the only thing 3D Mark is good for is measuring system performance relative to other similar system configurations and taking a diagnostic view of things. That is to say, if x system is getting x 3D Marks, then another system with the same components should achieve similar results. There are many other tests that will do the same thing, so while 3D Mark is useful in this way, it's not any more useful than any other synthetic benchmark.
That's the overall score you talking about, what I'm saying is say the graphics score of card X is higher than the graphics score of card Y by 20%I'm sorry but that's just not the case. 3D Mark isn't an indicator of overall performance because its numbers do not translate into anything meaningful. You can't say a score of 18,000 3D Marks equals 120FPS at 3840x2160 in Crysis 3 or anything so specific. It doesn't reflect performance relative to game engines because it isn't using any game engine. 3D Mark performance can be improved by CPU upgrades or clock speed increases that wouldn't have the same effect in games. Going from 4.4GHz to 4.6GHz for example might give you a significant jump in 3D Mark scores but that increase won't translate into substantial FPS gains.
