spacetrader
- Dec 12, 2008
There's a large difference between having a slow CPU and having a CPU that's not top of the line.
Honestly, an X2 clocked at over 3 Ghz should have no trouble running a 360 port at console settings (without the AA of the console version to boot), not when it absolutely decimates every other 360 port out there. I don't understand how you can argue otherwise.
why? an x2 clocked to 3ghz and a 8800gt video card is just about the same as an xbox isnt it? then the port should actually run much slower on the pc, and it does. also, when you step up a notch on pc power, like a core2duo, you see the game runs 30fps+. even if the game is ported poorly, ive seen MUCH worse.
