- Aug 7, 2004
Can somebody with an i7 and this game installed post benches with HT enabled and then disabled? It might be helpful for the rest of us...
perhaps you should have looked at reviews before wasting your money. the Phenom II X6 does absolutely nothing more for GTA 4 than your current X4. really going from your cpu to the Phenom 2 X6 is silly if you are trying to improve gaming. the only slight advantage it has is that it can oc a little bit better.I just ordered the new Phenom II X6 and I'll report back if this game scales with more physical cores. If it does, and my chip can hit 4GHz, I might have finally tamed the beast.
Where did I state that I solely bought the 1090T for GTA IV? I was only thinking of an incidental boost. By the way, which review tested GTA? The few I looked at didn't test it.perhaps you should have looked at reviews before wasting your money. the Phenom II X6 does absolutely nothing more for GTA 4 than your current X4. really going from your cpu to the Phenom 2 X6 is silly if you are trying to improve gaming. the only slight advantage it has is that it can oc a little bit better.
So does Episodes From Liberty City come 'patched' to 6, or how does that work?
