One of my friends asked me to recommend him a small portable laptop that can run diablo 3 and starcraft 2 (medium-low settings) under $700, so I did some research and found the 14" HP DV4-5100 with 2nd gen i5 and a 1GB GT 630M card.
It fits all his needs; the only thing I'm worried about is heat issues. I first thought the 630M was kepler so it would generate less heat. But it turns out to be more like a rebranded GT 540M, and I know a couple of people with that card in 15.6" laptops that get 90+ degrees celsius while gaming.
If so, I can only imagine the heat issues being worse in a smaller chassis. Does anyone have any experience with the 630M? And if it is a poor choice for a 13"-14" laptop, what's a better recommendation for my friend?
