turn your psu off but leave it plugged in, now you can ground yourself(touch it). no need for a stupid strap or a fake wireless one.
youll still ground out but if you doubt it, screw a steel screw into one of the screw holes and touch that.I read about touching chassis, PSU, electric radiator but the issue is that they have plating and that in order to transfer static charge the spot I am supposed to touch should not have any plating. It should have pure metal to conduct static discharge.
Inserting ends of an unraveled paperclip into the middle two ground sockets of a molex connector that's connected to such a powered off PSU I've also read is effective if a case and PSU is painted/etc.youll still ground out but if you doubt it, screw a steal screw into one of the screw holes and touch that.
yup, that would work too.Inserting ends of an unraveled paperclip into the middle two ground sockets of a molex connector that's connected to such a powered off PSU I've also read is effective if a case and PSU is painted/etc.
No, one works, and one does not.Hello,
I saw grounded wrist anti-static bracelet and non-grounded one. The latter is more convenient because there is no need to look for ground and you are not space-restricted.
I wonder if non-grounded bracelet works equally well as grounded bracelet.
Thanks.
No need. Most of those thousand dollar parts are pretty dang difficult to break and you can take proper precautions that makes it even more difficult.Grounding works, because the Earth can be viewed as an infinite source/sink of electrons. I fail to see why anyone would risk thousands of dollars equipment because they can't be bothered to wear a cheap grounded strap. Just crazy, as is any 'non-grounded' fake grounding device - Jeez.
