Been thinking about this for quite some time now.
Whenever I go shopping for a new GFX card on newegg, I narrow it down via specs and there are usually a few versions left over. In this case, I'm looking at a 6950 2GB by either Asus or XFX. When I do a compare, the only thing different is the model/serial number.
What is the actual differences between them?? Usually one of them has a ton of reviews while the others will only have a handful.
Only reason I'm asking now is that the ones with tons of reviews are OOS. Would there be any detriment to buying the "same" card with less reviews?
