TechLarry
RIP [H] Brother - June 1, 2022
- Aug 9, 2005
Is there a graphic equalizer you can get that works at the system level and can adjust the sound before it goes out USB to the DAC ?
I'm sure I used this a long time ago but couldnt find it on my PC and couldnt remember the name.Have you tried Equalizer APO? I can't say for sure if it supports USB audio, but it's definitely the most powerful system wide windows EQ I've found and would be surprised if it didn't
Just remember that an EQ is a poor mans solution for fixing problems that really can't be fixed using an EQ
Yep, many songs need EQing to sound their best.
Old Bowie, LED Zep, old Abba, old Floyd, some shrill sounding modern albums ...
When I was young I used to know the exact position on the bass control for every single song to get the best from it.
Not all hifis can be perfectly set up.
WAF and physical limitations apply so there may be some correction necessary.
Hehe yeah yeah yeah.One of the worst offenders are old Beatles albums, ow, my ears.
Ok, foobar actually has an eq that works.
There are 2 equalizers for foobar. There is the one it comes with and another you can download from the plugins page.
http://www.foobar2000.org/components/view/foo_dsp_xgeq
Actually, make that three.
http://www.foobar2000.org/components/view/foo_dsp_eqsplit
But....
WTF is up with all the love for this program ? It reminds me of a 1990's telecom program.
You can fix that by listening to the mono versions. Those are the correct real versions.One of the worst offenders are old Beatles albums, ow, my ears.
Yes, that helps with stereo separation issues but they are still not very good recordings even in mono.
With a good speaker you can listen to the recording as it is. Trying to 'fix' the recording through EQ may help a bit in some cases but in the long run it's futile. You'd have to readjust your eq for every recording. What happens in the end is that you probably just leave a 'smiling' eq on permanently and listen to a jilted sound from all recordings.
Of course the option of adjusting the settings constantly is even worse - you're never happy with the sound then and it removes the joy from listening to the music.
Once you achieve a certain level of fidelity in your system you'll realize that no adjustments are necessary. You listen to the recording as it's playing and it sounds as it sounds, flaws and all. Many times with a real good speaker set even ancient recordings 'pop' to life with a realistic sound stage coming from the simple 1 mono / stereo mic recording technique.
I never use EQ to fix recordings anymore. I use REW and UMIK-1 measure and use REW's auto EQ custom tuned close to the Harmon curve and apply the PEQ's to my DSP. Boom, never have to readjust anything, at the most maybe a bump or two on the subs for really old recordings but I rarely do that. One of these days I'll upgrade to Dirac Live.
I once had a fancy yamaha eq with led displays (rare 30 years ago) that cut everything above 16khz unless bypassed lolExtra physical connections and devices in the signal path can reduce detail.
Depends on the quality of your kit and how its setup whether you will notice.
Speaking from a music production standpoint:
One of the key tenets in obtaining a good quality recording is to start with a good source. No amount of processing will turn a badly recorded guitar into a well recorded one. You can try it all. EQ, phase correction, BBE Sonic Maximisers, Exciter Plugins, Compressors, etc.
At the end of the day you cannot polish an audio turd.
Some, like this Burzum album, were intentionally recorded terribly, for effect. (Guitars on this album were recorded into a bunch of fuzz pedals and a hifi. The vocals were done on a headset mic found in the studio)
That was quite an ear fuck.
That album isn't even that bad, at least most of the instruments are clearly audible (not counting bass guitar cuz metal is notorious for having bass guitar lost in the mix anyway). He should've picked Ulver - Nattens Madrigal.
I love that album but it shreds ears.
I'm amused by Burzum on [H] oh and Varg purposely asked for the worst gear in the studio for that album and I think the mic was broken...
I'm probably one of the few that listen to music like this on Electrostats.
If I heard 'music' like that on electrostats as the first contact to ESLs I too would spread false rumors about their tin can sound quality. OUCH!
I agree, the whole chain is important, but it's rather a lot like PC hardware in that you have "bottlenecks".
If your bottleneck is the source, the PC analogy to this would be a game that just doesn't look good even with the graphics on max settings and all the Nvidia quality settings turned up for good measure. You can throw as much horsepower at it as you like, but once you've exhausted the limits of the source, you're just not going to be able to do anything more to make it look fantastic. (At least, until the producer brings out an HD remaster. How fortunate that the two industries use the same terminology...)
