GPUs (not video card specific)
Cod
I have a few questions about GPUs that i was hoping someone could shed some light on for me. First, will CPUs ever be able to work at the same level of GPUs? Next, on a related note, why do we even use CPUs? Can't a GPU do a CPUs job and more powerful / better?
I'm sure I'm missing some important concept that makes CPUs valuable, but figured I'd ask to see if one of the processor gurus on this forum could help me out in seeing it.
What do mean exactly did you mean by your first question? No a GPU cannot be used as a CPU yet.
GPUs excel at highly parallel tasks, while CPUs work with much more diverse instruction sets.
There is some progress on GPGPU but I don't see the technologies converging any time soon.
GPUs are an "embarrassingly parallel" architecture for floating point operations. If you give them, say, 1024 operations to perform, and not one is reliant on the state of any other, you can successfully exploit their parallelism and reap the benefit of being able to perform many operations per clock cycle. A CPU is a bit 'smarter'. It doesn't stumble over itself in branches, offers good integer performance and has fast, low-latency caches typically large enough for small blocks of data being worked with. CPUs are best tasked with performing small operations which cannot be trivially paralleized or simply must be performed sequentially. In this sense, they're useful for logic, not just numerical computations.
I could see GPU technology eventually merging into CPUs in a way that's more tightly-coupled than current-generation on-die GPU implementations, but I don't know when that's going to happen.
