Will be gaming 90% and doing web-based work-related stuffs but mainly gaming.
~$500 mark, this is flexible.
US, Indiana near Fort Wayne.
I am looking to mainly upgrade the GPU and PSU. The CPU is a possibility but wasn't looking for one.
Everything is being resused aside from GPU and PSU
6) Will you be overclocking?
Maybe a smidge but nothing extensive, AMD Overdrive or Afterburner kind of OC.
ASUS 23", 1980x1080. I have dual monitors.
As soon as we have a solid discussion on appropriate hardware I'll be making orders.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
So far my current motherboard is sufficient for all of my current needs.
Windows 7 64bit, activated and legitimate.
Current hardware:
Monitors - ASUS 23.6" x2
http://www.newegg.com/Product/Produ...a&cm_sp=&AID=10440897&PID=3891137&SID=rewrite
SSD - Crucial M4
Hard Drive - WD Green 640GB
Hard Drive - Samsung Spinpoint F3
RAM - G.SKILL Ripjaws (2x2GB) (2x4GB) 12GB Total
CPU - AMD Phenom II X4 965 Black Edition
CPU Cooler - ZALMAN 120mm
Motherboard - ASUS M5A97
Case - Antec Three Hundred Illusion Black Steel ATX Mid Tower
Sound Card - Razer Barracuda AC-1
http://www.newegg.com/Product/Product.aspx?Item=N82E16829153003
PSU - Antec TruePower 650W
GPU - XFX Radeon HD 6950 2GB
The PSU that I was looking at:
http://www.newegg.com/Product/Product.aspx?Item=9SIA24G28N5310
Was also considering the XFX Radeon R9 280.
However I'd like a second or third opinion on this. If there's another upgrade that you'd recommend I'm all for hearing about it if that makes sense. While I'm looking to upgrade the PSU and GPU I'll take suggestions on other hardware as well if you have them. As noted above, my budget is flexible within reason.
As always, I greatly appreciate the time and suggestions that you guys bring to the table!
Current hardware:
SSD - Crucial M4
