Well it all started here
and being real bored I decided to lap my GPU
Taped off and covered the card, then took some 400 paper and sanded till I saw that beautiful copper(guess I voided the warranty
cleaned the mess up with 91% alcohol(antimicrobial) schmeered Arctic 3 on, back on went the Zalman heatpipe(with fan),shoved the SOB back in the slot, turned on the comp and ......nothing crap.
Took 3 times before I realized that I forgot to hook up the monitor(make note to self, self idot)plugged in the monitor and all is as it should be
while its to early to really tell, intial results show around 4C drop in temps and higher potential for ovclk.
Just can't kill the sucker!
Maybe I should flash to 5950 bios?
