Not exactly. We have a group of workstations that have an application which needs custom settings in the user's hive.so each user has a different GPO depending on the system they log into?
Yes and yes.so each user has a different setting depending on what workstation they use?
is it the same for each user who uses the workstation?
Actually, I was going to just setup a GPO and filter by workstation group, then attach that to the highest common OU for the workstations.Why not create a different OU for each workstation (if there are only a few) and setup a different GPO for each OU.
