Got my first legit site and need basic help please.
I currently have my site at
www.mixedmartialartsarena.com
that is my sloppy design..lol..now that I got a paid host I can implement scripting...I heard post nuke or php is what i wanna go for, for an easy build and good looking build...I still want light orange or just a lighter color look to the site but I want more clean organized vibe and compact...also i want a content management system with registration capabilities and comments...so can anyone point me in the right direction to giving my site a face lift? thank you for all your time. :p
how do i have "nasty" pop-ups? I have a paid hosting and domain from 1&1...i've never gotten any pop ups from my site and no one has ever told me about pop ups..maybe you need to clean out your cpu?
I got a popup too, but it was blocked immediately. Don't try blaming my computer either. It's a VERY fresh fresh install.
This looks like the source of your popup problem. I kept closing them, but they kept re-spawning. Not a nice thing to subject your visitors to.
Code:
  motigo_webstats("AENyfAyWrA1D3SX40GVcpXZ6b3Gg", 0);
</script>
<noscript>
<a target="_blank" href="http://www.webstats.motigo.com/stats?AENyfAyWrA1D3SX40GVcpXZ6b3Gg">
<img src="http://m1.webstats.motigo.com/n?id=AENyfAyWrA1D3SX40GVcpXZ6b3Gg" border="0" width="18" height="18" alt="Motigo Webstats - Free web site statistics Personal homepage website counter"/>
</a><br />
<a target="_blank" href="http://www.webstats.motigo.com/">Free counter</a>
</noscript>
<!-- End Motigo Webstats code -->
well my question then is why don't I get any pop-ups? I'm not trying to subject my visitors to anything bad...that's ridiculous...I made this site for the people not for myself...so the motigo is the bad stuff? is there a certain line i can take out because thats my referral tracker
okay i took that code out and put google in..now can the issue at hand be helped please? thanks again for the help!;)
I don't know... do you have any popup blockers in place? I sure got them, then I cut and pasted the motigo code into my address line and the whole thing happened all over again, so it seems pretty obvious to me where the popups must be coming from.
You may have accessible stats reports available thru your host, or might be able to install your own. If you want a third-party freebie, I have found this one to be pretty good.
extremetracking.com
Can I say I find it fugly? It looks like a total mishmash without a cohesive theme. It's all left aligned, not even centered. And the news portion doesn't display at all in the older version of Firefox I have.
Agreed! The two banners at the top of the same image just doesn't look good IMO. Also, the bright orange on white kind of assaults the eyes, and keeps wanting to pull my attention away from the rest of the content.
Code:
<meta content="Microsoft FrontPage 6.0" name="GENERATOR">
<meta content="FrontPage.Editor.Document" name="ProgId">
That's a pretty big problem to. ;)
It's a good start, but you've got some more work to do!
ok i really appreciate everyones time but i already said i know its sloppy thats why i made this post so that maybe i could get advice on ways to clean it up...scripts to get...so forth and so on.....hurdler the code you pasted...i dont get it buddy...whats the problem with it..im new when it comes to the coding aspect...lol...thanks again.
You are using FrontPage, which is notorious for generating really crappy code.
well it's really simple for me and ive used it since i was 15...i have dreamweaver but i get confused...lol
Yeah, Frontpage results in really bloated code. There's not really anything *wrong* with it, other than it takes far more code that it should to do things. I will agree that Frontpage is simple, and I did use it for a while. Now it's Dreamweaver and Notepad FTW!
yea im gonna have to learn the ropes with dremweaver then...also im checking out this e107 and if i can install it correctly i think i might just make the site using that...it looks good...im installing now.
Notepad is king. Notepad is free.
WYSIWYG editors always generate too much code. They have to do almost too much to make sure it produces what you're going for.
However, if you must use an editor, I'd have to recommend Dreamweaver over FrontPage. If you think you'll get into scripting languages, like PHP, I'd recommend PHP Designer. I used the trial and it's a great program. I still prefer Notepad, although PHP Designer (and other PHP editors) color-codes different elements, and sometimes I can't figure out what ending brackets go to what if statement.
The reason you didn't see the pop-ups is the same reason you don't test on your home PC--you have your home PC configured just the way you want it, which will include such things as pop-up blockers, filters, etc.
You need a REAL test environment--go get VirtualPC and install a fresh copy of Windows XP SP2 or Windows Vista on it, then without running Windows Update or anything else (other than what is done normally through the Vista installation, in Vista's case) navigate to the website with IE and see what happens and how it looks.
If you can't design a webpage that works after doing what I stated above then you have user issues that need resolving first. :)
202276
