Got me a e-machines mobo....need some thoughts.
Monkey34
I got a mobo from an e-machine (AU31-L). I kind of back-checked what it comes from e-machines with (seeing as I couldn't find any spec's for the thing), and found it comes on models stock with pc2700, and cpu's from the xp2600 to the 3200.
What do you think I can max this board at for cpu and memory? Nforce 2 btw
I'm just wondering if they restricted the bios settings. this was all I could find:
Processor Supported
AMD Duron™ Processors up to 1.3 GHz
Athlon processor up to 1400+
Athlon XP 3200+ and up
200/266/333/400 MHz FSB
Chipset
North Bridge: Nvidia nForce 2 IGP
South Bridge: Nvidia nForce 2 MCP-T
Main Memory
Two 184-pin DDR DIMM sockets for 64-bit, Unbuffered, Single/
Double-side and Non-ECC DDR-200/266/333/400 (PC3200) DIMMs
Supports 128-bit dual channel memory architecture
Supports up to 2 GB memory size
Supports complete FSB/Memory and FSB/AGP Asynchronous scheme for over-clocking
I would just find out who makes it what board it is and flash the bios to the newst one. Then read the release notes for the bios.
Without flashing the bios, you're probably stuck with a 3200+ since that's the highest XP they made (AFAIK), and you won't be able to OC. Semprons might work, but you'd need a bios flash very likely.
Thanks for the link...I found a little here and there, but not the whole.
:rolleyes: now I gotta find a cheap cpu + ddr to test this thing first .
