First of all, I live in Finland
I had ordered AMD ATHLON 64 3200+ TRAY S754 ADA3200AEP5A (2.0GHz with 1Mb L2 cache) for 170 euros. I wanted it because it had 1Mb L2 cache unlike the new S754 ones with just 512Kb L2 cache. The place I ordered it from informed me just now that they can't send it to me, because they can't get that processor from anywhere anymore.
For the same price though, they offer to send me AMD ATHLON 64 3200+ TRAY S754 ADA3200AEP4AX. This is a 2.2GHz with 512Kb L2 cache.
Isn't AMD ATHLON 64 3200+ TRAY S754 ADA3200AEP5A with 1MB L2 cache, 2.0 GHz
alot better for an overclocker compared to
AMD ATHLON 64 3200+ TRAY S754 ADA3200AEP4AX with 512Kb L2 cache, 2.2 GHz ?
Or does it not affect much at all that the other has twice the L2 cache the other one has? The 512Kb L2 cache has got 200MHz more as default. Which one overclocks better? Should I accept the switch? Is the newer Newcastle core better for overclocking than the older Clawhammer core? Please help if you have any information about this matter!
