Hey friends,
It's been a long time since I've posted here -- I hope everyone is well. I have something to share with you all:
After two years with this loud, dusty, defective card--I've had it. The fact that it builds up so much dust in such a short amount of time--that it routinely overheats while idle--is unacceptable. It's not something to put up with, it's a design flaw.
About six months ago I tinkered with replacing the hunk of junk with a 5870, but decided not to since it wouldn't be a performance upgrade of any sort. Now with the GTX 460 SLI setups taking names, I'll bite. Still, I decided I'd give the card one last shot by finally dismantling it piece-by-piece for a thorough in-depth cleaning, as others have suggested I do. I don't know how others manage this, but this was by far the most difficult piece of hardware I've ever disassembled. I have bruises just by getting the eight backplate screws off, and that's after trying three different variable-head screw-drivers and two jeweler sets. It's impossible.
So I gave up, threw the fan shroud away, and proceeded to transform the card to its above form. It felt good. Very good. I think, given all that this card has put me through, that it was worth the $120 or so I may have been able to fetch if I resold it.
Now then... the question is, what should I replace this with? =)
