Good Stable Mobo?
Daedro
So I'm looking for a well-known (popular) stable motherboard that I can use with a Intel Core2 Duo.
I've got the ASUS A8N-SLI Premium and I swear to god it's screwed up. I've went through 3 hard drives the past 2 months. First my ATA WD drive dies after less than 6 months. Then the ATA RMA starts to die so I buy a SATA. By starts to die I mean the SMART variables start changing for the worse. "Spin Up Time" and "Seek Error Rate" lowering. Then it dies after less than a month. I'm now using a SATA Seagate Barracuda. The "Seek Error Rate" went down 40 points, and went up 4 points. So I'm a little freaked out. The thing is I read these harddrives aren't even dying, some people have switched motherboards and they worked perfectly fine. Odd. It's also making a noise when reading, but I read that's normal with certain models. However I read others with my model and same design that don't have noise issues. (Theres three different manufacturers for the model I have, wow).
I also had a problem running my cd-drive, so I replaced it, and still had the problem, basically it would start running and my computer would crash. I think that was a power issue. It's all working now that I replaced the PSU.
I was using a bad korean PSU for those 6 months and I have no surge protection so I think that's why it might have these problems. However, a lot of people have problems with this mobo. A LOT.
Mobo's don't kill HD's bad PSU and co do
If you don't need SLI go for P5B dlx or P5W-Dlx (these chipset only support crossfire)
P5B enables high overclocks, P5W is faster clock for clock but mostly limited at 420Mhz FSB....
If you need SLI only Nvidia option to go 650i or 680i ...
680i bugs are mostly ironed out, still some issues with quadcore and 4 gigs of ram but newer biosses will hopefully solve those, 650i is brand new and needs also more bios updates to be bulletproof....
At stock speeds no worries for neither board just when pushing them a bit harder you can run into trouble with the latter as they are very sensitive to adjustements you make
I'd say one of the P5B series from Asus or the Gigabyte DS3 depending on the features you're looking for. If you need SLI, the cheapest 650i boards "only" do x8/x8 SLI like your current Premium A8N board. The cheapest x16/x16 SLI board is the Asus P5N32-E SLI Plus with the 650i/570 chipsets working together for SLI. 680i boards are the most expensive and perform about the same as the Asus Plus board mentioned earlier. eVGA is probably the cheapest and has good reviews and a wide user base.
I replaced my PSU with a great OCZ 700W GameXStream. So what's a "co"?
