Hey all,
Okay after a couple of months of thinking hard about my big upgrade, I think I've finally decided what to get.
Please note my current rig is:
» Aspire X-Cruiser (Blue) » Core 2 Duo E6600 » AC Freezer Pro 7
» Gigabyte MB » Corsair 2x1GB DDR2 » 8800 GTS 320Mb OC2
» Corsair HX 620W » 500GB WD/280GB Maxtor HD
Here is what my rig will be, after the upgrade:
CPU - E8400 Intel Core 2 Duo
CPU Fan - AC Freezer Pro 7
Motherboard - Asus Maximus Formula
RAM - 4GB Crucial Ballistix DDR2 PC2-8500C5 1066MHz
Graphics Card - ATI Radeon HD 3870 X2 1024MB
PSU - Corsair HX 620W
HD - 500GB Western Digital
Case - Antec P182
(Bold items are the items that I am upgrading to - standard items are the ones being used from my current rig)
After this upgrade, I plan to; upgrade my screen from 19" to 24", get some decent speakers, and possibly add water cooling!
Basically, just want to make sure you all think this is a good upgrade and all the components work well with each other.
If you have any recommendations on things I should change - go ahead
Thanks,
Rezz
Case - Antec P182
Thanks,
Rezz
