I'm trying to find a good pair of headphones that I can take with me and use with my new laptop. I'm having a hard time finding something quite like what I'm looking for unfortunetly.
Price range: <$110
Connector: 3.5mm
Noise Canceling: No, less energy used the better
Should also note that I don't yet have a sound card, but I intend on getting that shortly.
I came across a few things that I liked for the most part.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826627004
These BOSE look nice, but that price is a little too high for me, but something similar to those would be good.
I came across http://www.newegg.com/Product/Product.aspx?Item=N82E16826106333 next, which also seemed good, and that price is fine by me, but the one negative about that is that they are "Open" and according to the reviews, people around you will easily hear everything you hear. This was sort of a turn off as some privacy is nice, I plan on using the headphones in public places, and want to have at least a certain level of privacy.
Additionally, I just now looked in more than just newegg's 3.5mm category (I wish I could view all that have 3.5mm connectors, not 3.5mm only, or 3.5mm/6.3mm, don't like how they split them into 2 categories). http://www.newegg.com/Product/Product.aspx?Item=N82E16826158054
Does anyone have any suggestions? Remember, I want them to be durable seeing as I don't want to be replacing them all the time, I will be taking them with me.
Price range: <$110
Connector: 3.5mm
