Good Overclocking Motherboard?
CDdude55
So i have decided to overclock, but i need a good motherboard with the features to do so. Any have any good suggestions. Any help is appreciated:) .
You're a bit vague - which CPU do you intend to use, what mobo features do you need (RAID, firewire etc.) & your budget?
Intel Core 2 Duo, But no RAID. I just want any good overclock feature. budget is $900
$900 for what? The whole thing? Do you have an operating system already? Hard drives? What's your motherboard budget?
$900 for the whole system. I want to spend at least $100 to $180 on the motherboard. I already have a harddrive. I still need an operating system tho, which will be Windows XP.
I'd go with the cheapest of the P35 DS3 motherboard (DS3R maybe?). It runs around $130, I believe it has Firewire and RAID (although you don't have to use it...it has the ICH9R). Either that or the Abit IP35.
You need a DS3P, DS4 or DQ6 to get firewire on Gigabyte.
IP35 is the cheaper option if you need firewire.
