djoye
- Aug 31, 2004
My niece wanted a gaming PC and specified a budget ($1500), I didn't want to even think about or have to deal parts availability, so I considered pre-built. I remembered either JayZTwoCents or LinusTechTips mentioning that NZXT did well with their pre-builts. I referred my niece to NZXT's Starter Plus PC (currently H150 case, 500GB M.2 NVMe drive, RTX 3060, 16GB RAM, i5-10400F) and she ordered it; I advised her to let me unbox it in case we needed to deal with build, packaging, or shipping damage.
Received the PC double-packed with formed foam inside the case to keep the GPU and CPU heatsink in place. Everything in excellent shape and in its place. There was an extra case thumb screw loose in the backside of the case, but it doesn't appear to have caused any issues.
Pros:
Edit: https://nzxt.com/product/starter-plus -- Link that will probably become outdated at some point
Pros:
- It arrived exactly as pictured. The cable management is awesome front and back of case; super clean.
- Additional SATA cables are included and brackets for mounting 2.5" drives are on the backside.
- Real parts used, no proprietary crap that can't be easily replaced or upgraded -- all parts are common/standard parts that can be used elsewhere or upgraded
- No bloatware installed, just Windows 10 that you perform final setup on. Gigabyte RGB Fusion was installed or installed itself, not sure if that came from Windows update. Motherboard is a Gigabyte B-something.
- The GPU was some kind of MSI VENTUS OC model with 12GB. Not sure if that's luck of the draw because the exact model isn't specified on the specs area.
- Can't really think of anything other than the extra loose screw in the case. It being in the backside of the case probably kept it from doing any damage.
- Use CPU-Z to identify the motherboard and then download motherboard drivers
- Update UEFI/BIOS
- Update GPU drivers
- Configure secure boot -- Not sure if I really needed to do anything or if it just finally worked after a few reboots
- Enable the CPU's TPM function to meet Windows 11 pre-reqs
- Enable above 4G decoding then enable Resizable BAR for the GPU
- Enable the RAM's XMP setting
- Windows updates
