Good Cooling for the old AXP?
Unperson
I've got an Athlon XP 2500+ and unfortunately I couldn't overclock with my old board. Got a new one because the old one didn't like my shiny new GeForce 6600 GT, and i've found the AXP is born-again [H]ard. The problem is, even at stock speed it is running prety hot ( 45+ * c.) with ambient just over 30. My friend's brand new A64 3000+ 939 runs at like 33*c when ambient is 30*c and he has stock heatsink. My heatsink is a Coolermaster all aluminum heatsink w/ 80mm fan. Right now with a 370MHz overclock, Prime 95 is cranking it up to almost 70C.
I've looked at heatsinks both online and at KompUSSR and it seems like they ahve gotten expensive, with many being near and above $50. I'd prefer not to spend that much on a heatsink, especially if i won't be able to use it when I upgrade to Athlon 64 probably at the end of this year (Dual core :D ) Are there any reccommended heatsinks in the $20-30 range? Fan need not be included, especially if it's 80MM because I can get tons of 80MM fans from work. Also a friend of mine works at CompUSA so if there are any good ones there (rebagged etc.) I can probably get them for a good price.
Anything that can take care of a Palomino 2100+ (72W) or a XP3200+ (77W) should be sufficient for a XP2500+ (68W)...
It also depends on what kind of realestate you have around your cpu on your mainboard...
Cooler master is a so so brand that's usually adequate, but IMHO is just a temporary solution, I ran one for a while and got rid of it pretty quick.
Make sure you use a really good TIM, Arctic ceramique is one of the best and it's non conductive.
I wouldn't compare it to a K8 architecture, since K8's have built in cooling features not found in the K7.
Have you tried any bus disconnect software to reduce the temperature at idle on your cpu?
I use this with the setup in my sig:
http://www.stargaz0r.nm.ru/files/s2kctl15b101.zip
MD's Temperature related standard checklist.
Check the following for overheating or perceived overheating:
- Is the heatsink correctly installed ?
--> Verify it is correctly installed.
- Is the heatsink filled with dust and crud ?
--> Clean with compressed air in a can.
- Is the heatsink fan operating ?
--> Replace defective fan with similar or better unit.
- Is the heatsink adequate for that application/CPU ?
--> Verify it meet the requirements for the CPU being used.
--> RETAIL heatsink? May require lapping and better TIM.
- Is thermal interface material used between heatsink and cpu ?
--> Verify it is used, and is applied according to the manufacturers guidelines.
--> Recommended PCM's, thermal pads from "AMD Thermal, Mechanical,and Chassis Cooling Design Guide #23794.PDF.
- Bergquist HF225UT Phase Change
- Chomerics T725 Phase Change
- Honeywell PCM45 Phase Change
- Power Devices Powerfilm Phase Change
- ShinEtsu PCS-TC-11T-13 Phase Change
- Thermagon T-pcm905C Phase Change
--> Recommended thermal interface material aka: grease, gel etc.
- Arctic Ceramique.
- Arctic Alumina.
- Arctic Silver, 3, 5 etc.
- Is the TIM pad cover removed from heatsink before installation, if using supplied TIM pad ?
--> Remove the cover before installation, failure to do so will insulate the cpu from the heatsink.
- Is there adequate airflow or case ventialation ?
--> Verify airflow, add case fans if required.
- Is the Vcore set higher than specified by the manufacturer ?
--> Verify the Vcore is set to the manufacturers specification in the mainboards bios.
- Is the temperature read via the internal temperature diode. Is the tremperature read via the socket thermistor ?
--> Temperatures read at the diode can and will be higher than an external reading.
- Is the temperature sensor properly calibrated ?
--> Several boards have this problem, check manufacturers bios revision history for calibration fix.
--> Does the heatsink feel warm or HOT, if it's warm it could be a miscalibration error.
- Outside temperature high ?
--> If the external temperature is high, then the case fans will be drawing in hot air, especially during summer months.
Good Luck
MD
Thermalright SI-97. It's not too expensive and worth every penny. My overclocked XP-M 2500+ runs at about 45c under load, and that's the diode reading. With the stock cooler, I was getting nearly 60c under load and the diode reading was usually about 10 degrees higher. Now it reads almost exactly the same as the normal cpu temp sensor.
it usually sells for more than your stated budget, however the zalman 7000 AlCu heatsink is one that would give good and quiet cooling on your current system, but would be something that you could use on an a64 later. thermalrights don't have that flexability, but are lighter and better performing.
i really like thermalright's current linup of heatsinks, but if you can swing the cash now then the zalman is something that you should get added mileage out of.
Spraying the heatsink with air and reducing the voltage by 0.025 dropped the temp down to ~64~63. ROCK solid at 2200 MHz / 1.775v. Ran Prime 95 torture test for nearly 4 hours straight with no errors.
I was looking at the SI-97 but I don't think it would fit. I have a mid-tower case, and the board has the CPU about as close to the top of the board as possible so anything significantly really huge heatsinks won't work (without some dremel action at least)
The Zalman heatsink looks good, especially if it works for AXP an A64, and price isn't too bad either. Again, just have to make sure it fits. I could always get [H]ard on the edge with the dremel or just get a bigger case though.
