Good Cheap Motherboard
Blinkme323
My dad has a P4 2.0ghz 400 bus Compaq machine with 512mb pc 2100. He has an oppurtunity to trade it straight up for a P4 2.8/533 and 512mb of pc3200. The problem is the motherboard supports neither of them. It is a crap motherboard anyway, so he wants to replace it with one that supports the new parts. I would prefer something that supports 8x AGP, 533 bus, and pc3200 memory. It would also be nice if it let me overclock a little bit. He doesn't want to spend more than $30. Are there any cheap budget boards like that. I found this on New Egg:
http://www.newegg.com/app/ViewProductDesc.asp?description=13-139-134R&type=Refurbished
He doesn't need it to be anything great. As long as it gets the job done. Any suggestions?
I'm not sure about the brand Soyo (no experience with it) but the specs look fine for what you want.
There were a bunch of other brands with similar specs for the same price in New Egg's refurbished section. I didn't really know any of the other brands so I posted the Soyo. Any suggestions? Also, will I have to reload the OS? It came with a Win XP disk that works in non Compaq machines. The power supply it came with is a TERRIBLE 230 watter. Do I have to replace that too and what is a decent cheap one. It has 2 HDs, 2 CDs, a floppy, and a Radeon 9100. Right now whenever it gets under load the fans start going crazy.
Wow, lucky for you it came with that XP disc for use in other machines! Very lucky. It's a very good idea to reformat/reinstall the OS after a major hardware change like that. The drivers that were for you other mobo most likely wont be compatible with the new mobo, and you can corrupt things fast. There have been success stories where people have successfully put in a new mobo w/out changing drivers and it worked, or they used it long enough with the old drivers to get the new drivers, etc, but it's DEFINITELY NOT reccomended, I would never do it...EVER, unless I wanted to take a chance of destroying something. By the way, your name "blinkme" you like blink 182?
Thanks for the help. I just did a fresh install but I can move important files over to the other hard drive and do it again. Yeah, I do like Blink 182. Lol.
Ahhh, Blink 182...too bad they're taking a "break" or an "indefinite hiatus" Makes me so sad, man. But, yeah, go with the reformat route
Hopefully.... I was on MTV.com and in an interview with travis, he said they're just taking time to be with their families and they'll probably come out with another "rad blink record". Hopefully they do, otherwise I'll have to riot rampage! You ever been to a blink182 show? the best thing, ever, man. I went during the take off your pants and jacket tour, and they had a huge "FUCK" sign on the back of the stage that was on fire....it was the coolest thing I ever saw! I was like :eek:
I might have to riot with you. Yeah I've been to two Blink 182 concerts. One had Green Day too.
I've never met a Soyo board I liked :). Just my $.02
Is that a prescott 2.8 or a northwood? I believe they made a 2.8a/533 Prescott just like the 2.4a/533 for socket 478. If it's a Prescott, it might not work with the PT800. Not sure. Might have to go with the PT880.
Soyo is not a good motherboard manufacturer. I've replaced tons of them my company bought a couple years ago. Others I've encountered since, reek of their asstastic quality.
The only good "cheap" mainboard I can think of is the D865PERL which can be had for as little as $75 on Newegg.
