Good case for big video card
Magice
I'm looking to throw together a beefy htpc that will fit in my tv stand.
Basically I need a case that will accompany a high end video card, expandability for fans to be able to cool the computer. The tv stand is enclosed so cooling will be essential.
Can anyone recommend me a case, I don't really care what it looks like.
It can be as big as a high end av receiver. If I have to I'll do a tower on it's side.
What kind of hardware, exactly, are you using? So it's a closed off (door over the components) TV stand?
Something along the lines of
atx board
4gb of ram
1tb hd
modular ocz 700w psu
bd drive
as far as the video card goes I'll be using onboard until I can afford a semi-high end card ($350~) I don't know which cards are on the market right now, I'm out of the loop.
The tv stand is a techcraft, looks like this
I will be installing some 120mm fans in the back of it, or ripping the rear panel off all together.
The Lian-Li PC-C33B can hold some pretty large video cards. I am running a 4850 crossfire in it with plenty of room. One of the newegg reviews mentions using a 5870 in it. This is about as big as you will get for an HTPC case. It is close to the same size as a large Onkyo receiver from a couple of years ago. I got it because it was the closes thing I could find to a mid tower on its side. Unlike most of the Silverstone cases I considered, long video cards will not block any of the hard drive mounting locations.
The case only uses 3 fans however. 2 80mm fans are used for exhaust and a single 140mm fan blows from the front to the back, over the video cards. The case is pretty hot with my Phenom II 955, 4850 Crossfire, 3 hard drives, 2 optical drives, and 8GB of ram. This is with a non-modular PSU (do not recommend this) that ends up blocking most of the airflow in the case, and using the 80mm fans that came with the case (that move virtually no air). The temps are on the upper range of acceptable though after long sessions of Prime95 or a long session of Crysis. For the heatsink, I am using a Noctua NH-C12P SE. This is about the largest heatsink that will fit in the case.
To give an idea of video card size vs. case size, I have one GTX260 in a Silverstone CW02 case. I have two 4870x2 in another Silverstone CW02 case. If you go with this brand and model case, PCIE slot placement on the motherboard is absolutely critical if you are going to double up on cards. The cards have to fit between the HDD cages and also have to clear the memory card reader at the bottom. And if you go IDE for the CD drive, and if that connector is low on the board, the cards will have to contend with that also. You will need to make sure that these cases can vent heat rearward and can take in air from the sides and bottom. I don't think you can fit a new ATI 5870 in this case given it is something like 12" long-- 1" longer or so than a 4870x2-- so you will have to check on it.
A Silverstone TJ07 will take just about anything you can throw at it but laying it down on its side could be problematic for airflow.
