1) The purpose of the PC is to play Starcraft 2 on Ultra smoothly
2) Budget is about 500 - 550 total.
3) i am starting from scratch so no parts will be reused.
4. Yes I will be over clocking the PC
5. Planning on getting a 21 inch screen
6. I dont really need raid, firewire or crossfire or SLI...this is a budget PC..the sole purpose is to play Starcraft 2 on ultra.
7. I would like to run the 64bit windows 7.
here are the parts
COOLER MASTER Elite RC-310-BWN1-GP Black Steel / Plastic ATX Mid Tower Computer Case $39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119203
Western Digital Caviar Green WD5000CSRTL 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136334
ASUS DVD-E818A6T/BLK/B/G Black 18X SATA DVD-ROM Drive - Bulk $16.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135202
RAIDMAX HYBRID 2 RX-630SS 630W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Modular LED Power Supply $39.99 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152035
146.99 after rebate for both the CPU and mobo
ASUS M4A77TD AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131603
AMD Athlon II X4 635 Propus 2.9GHz 4 x 512KB L2 Cache Socket AM3 95W Quad-Core Desktop Processor ADX635WFGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103882
$178.98 for the Video Card and Ram after rebate
OCZ Obsidian 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3OB1600LV4GK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227495
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873
The CPU is probably have the most bang per buck under $100 dollars...i chose a decent CPU...Now i am just clueless on the mobo, ram, cd drive, power supply and case. I feel i can cut more but i dont know what to cut or which brands are reliable brands. uhmmm...any suggestions on the build? This build come out around $520...it would be awesoem if i can squeeze it down to $460.
Thanks a bunch!!!
here are the parts
Thanks a bunch!!!
