Stupid_Newbie
- Dec 4, 2005
Ok, so i have decided in my mind to go WC.
Here is what I have decided, and what I need help with.
Im gonna try and get a triple 180 magicool rad. Apparently Frozen CPU is the only place to get them, so thats where ill go. Its for my raven 2. Ill re-use the AP fans in the bottom of my case.
I dont care what it looks like, I dont want LED shit, I want a good performing, waterblock, low restriction. Im gonna be blank paneling my side, with a non window door, which is $20 plus shipping from silverstone.
Id like to see some form of confirmation on EKs claim that a 6870 reference block will fit my GPU. They say yes, anyone seen a thread anywhere that it does. I have seen several threads that say it will work, but never a confirmed thread, by anyone who actually did it. I looked at the cards again today, im almost at the point, id drill a hole in my card for the last bolt. Yeah, im that unstable in the melon
I have been told that a single 3x180 will work better then two loops with a dual 180, and single 180 (single for CPU, 2500k), and double for cf 6950s (dual 180).
Im pretty sold on the 655 pump, but may go custom top to improve flow, and have g1/4 ports, not predone barbs. Is this the route to go?
Im not looking to spend a fortune, but to sink 500-600 isnt an issue. whatever it takes. Im not looking to break OC records here, im looking to run my CPU at 4.5-4.8 (higher if its a good chip of course, but a reasonable stable OC without too much vcore for little gain), and run my 6950 at 6970 lightning speeds, and add a second as needed, while not listen to the noise my last case put out (X850XT PE, 6 fans, SP-94 heatsink with loud 92mm enermax fan).
I dont want to hear this thing idle from another room like the last case.
So what do I realistically need to spend here. Is the 655-B a good quiet pump (i know its a good pump, but is there another option, that will suit my needs, and be a better fit for accousitcs?). What CPU block should I look at, is the sapphire still a good choice, or is there another cheap block to get it done.
Really im looking to get in a cheap as I can (who isnt), but wont give up performance hits. Mostly a bang for buck, quiet. I dont need the lowest temps, but still want to keep the temps low enough I dont need to run fans flat out in push/pull. So if that means more pump, or more rad, then so be it.
