silent-circuit
- Sep 18, 2005
I did look through the threads a bit before posting this, but in the end I have a few questions and putting them all in one place might make things a good bit easier.
Don't know what typical power from a single user is, but I should be able to bring around ~15-17Ghz over the next few days to the [H]orde, more if I can convince a friend of mine to let me borg the machines in his house, which shouldn't be too difficult and would give me an Athlon XP 2300+, an 800Mhz Via C3, 5-6 older Pentium II's and III's from 300Mhz to 1Ghz, a 2Ghz Turion64 X2 laptop... all in all a nice boost.
I've got a E6420@3.2Ghz in my sig rig that should be running 24/7 or thereabout and might lose 6-7 hours a day to actual use, and I may be ordering the better part of a nice watercooling setup from FS/FT here in a few days, so it could end up OC'd a good bit higher. Also have a 3Ghz Pentium 4 HT that sits idle 9/10ths of the time and also runs 24/7, a 2.6Ghz P4 HT I may play around with OCing if possible that will be folding only, 24/7, a 1.7Ghz Pentium M laptop that doesn't do much but browse the web and download the occasional file that will be folding, and a 500Mhz iMac G3 and Xbox that will be folding 24/7 as well. That's ~14.7Ghz there, then I have a few older Pentium 3 machines I may be able to get running Linux and the SMP client at some point ranging from 600Mhz to 1Ghz. Have a couple older PowerMacs as well, not sure if it would be worth including them... doubt I could even get OS X running on them, really.
OK, to the real reason for the thread, not just jabbering about all the machines I hope to use...
Already signed up at hardfolding.com with the same user-name "silent-circuit" and am already folding @11.1Ghz under that name for team 33. When will I show up and/or be able to log in on hardfolding.com? Do I have to finish a work unit first? I can't find this info anywhere, so it'd probably be a good thing to add to the FAQ. The site says "as soon as possible" which is vague to say the least.
People talk about losing work units in various ways, but I'm not real clear on the "do" and "do not" things, here. Can someone explain or point me somewhere that does? Am I more likely to lose work running the SMP client on my C2D machine? Should I run 2 instances of the regular console client instead to avoid this? Will it incur a major speed penalty?
Is there a bootable folding distro of Linux out there somewhere? I'd really like to be able to just stick a CD-R in this 2.6Ghz P4 I've got and set it loose, rather than spend several hours reinstalling the OS so it can sit there and do nothing but fold until it explodes.
Setup tips? Anything odd you think I might have overlooked or not done?
Thanks in advance,
silent
Thanks in advance,
silent
