Going from Nvidia to ATI, What to remove?
fantomau
I just got a Visiontek 4870 and I'm coming from a 8800gts card.
Wanted to find out, Do I just uninstall the nvidia display from add/remove only? Do I remove anything else?
Remove everything via add/remove programs, and then boot into safe mode and run Driver Cleaner. That will remove fragments (registry settings, .dll files) that the uninstall utilities don't. If you want to be completely safe you may want to reinstall Windows.
Most people here will tell You to use driver cleaner normally, use it in safemode and some will even tell You to reformat or/and OS fresh install. My opinion however, just add/remove only, if you're not getting the relative performance of the card, You might need to use that driver cleaner.
Oh, and just boot to normal mode.
uninstall nvidia drivers as normally, reboot, install ATI drivers ..
works great..
if you're overly paranoid you can remove registry settings but won't really matter..
Any links for this Driver Cleaner? I search for that and get alot of sites I dont want to download things from :)
Reinstalling windows for a video card upgrade??? I hope that was a joke
Hehe, I've told You.
That's pretty much what i do. Uninstall drivers via add/remove programs. Shut the computer down, remove old card, install new one, boot computer back up and install the new drivers.
9/10 times this will work fine, the other 1/10 you may need to use driver cleaner.
if it is going from nv based to ati based or the other way around i would recommend that, though this is coming from someone who reformats and installs windows everything 3 months no matter if there is a upgrade or not, i just like the feeling of a fresh os install myself
qft. add/remove and your usually set.
There absolutly no reason to do it unless you're that bored and have nothing better to do. The only thing that would validate a complete reinstal is a motherboard upgrade. CPU, video cards, sound cards, NIC's, and everything else is easily done by simply uninstalling and reinstalling drivers. There may be very rare occassions where there may be issues, but the vast majority of the time going from NV>ATI or vice versa is just as simple as staying with the same chip manufacturer.
second that, just remove at control panel. I have been testing the GTX260 and HD4870, keep installing/uninstalling drivers from both vendors, no problem
Don't listen to all these psychos who go overkill. Too many people believe in PC voodoo. Just remove the display drivers from add/remove programs in control panel, and install your new card. Even if files were left behind there's no way they could affect your ATI setup. Guaranteed.
Thanx all. Everythings working fine. Done the fan fix and brought the temps from 75 down to 47. I still dont understand why I cant run ati-tools. Everytime I try, It hard locks my system and I have to reboot.
I installed rivatuner and it says that the EDID maximum res reported by the driver doesnt match with EDID. Says max res is 1280x1024.
EDID info: 1280x1024 - DELL E228WFP
Driver info: 1680x1050 - Dell E228WFP
