Going from a core2duo to quad on same setup?
bL33d
Im have a major brain fart here but can i run a quadcore on my current setup since i have ddr2 800 ram? and if so will i be able to oc it?
the way i am figureing it i wont even be able to run a 1333fsb cpu at stock clocks??? :confused:
Yes you can run a quad core CPU. And yes you will be able to OC it if you go for a 1:1 ratio:
Q6600:
Multi x Actual FSB, Stated FSB, RAM Speed = Clock Speed
9 x 266Mhz, 1066Mhz, DDR2 533 RAM = 2.4Ghz <== Stock Speeds
9 x 333Mhz, 1333Mhz, DDR2 667 RAM = 3.0Ghz <== Good OC
9 x 400Mhz, 1600Mhz, DDR2 800 RAM = 3.6Ghz <== Excellent OC, About the Max
Q9550:
8.5 × 333Mhz, 1333Mhz, DDR2-667 = 2.83Ghz <<== Stock speeds
8.5 × 400Mhz, 1600Mhz, DDR2-800 = 3.40Ghz <<== Easy OC
