I just use Sickbeard and Sabnzbd. Everything we want is automatically recorded, organized, and is completely commercial free. And we pay $0 per month.
Legally? Wow, fill us in !
While using Sickbeard and Sabnzbd on it's own are legal, there's a good chance that the content being acquired isn't.Legally? Wow, fill us in !
No tuner available messages are normal in situations like coming out of sleep while the tuner initializes, etc; usually about a minute.
There IS an outstanding reboot issue that Ceton is working to resolve - could be that the tuner rebooted at some point shortly before (or during) when you were tuning the channel. You can check the tuner up time in the web diagnostics page.
Shentel can't get the cablecard to take the new channel lineup, so the new channels all say no subscription, or they bring up the wrong channel. Nat Geo is currently CNN.
Yay for nerd rage!
In the Ceton web page diagnostics, you can go to the CableCARD tab and at the bottom, there's an option to clear the current channel map - it should re-download the map. Not sure your specifics, but worth a shot. Or, open a case with Ceton and they'll help you out with your MSO.
I am having a problem with an audio popping noise when changing channels. After some research, I determined it to be a checkbox about allowing exclusive control of the HDMI audio device to applications. Disable that, no popping noise. However, disable that, and TMT5 won't play blurays. Need to find another workaround...
Everything still working solid?Mine's been very solid since I got a working cablecard. No more issues with the board not showing upon bootup.
I read through this entire thread and few others here and there, but could you sum any pointers or advice?
