Also, don't pull the cablecard out of the device when you first get it up and going, it messed up the firmware on the cablecard and it had to start over and completely re install the firmware which took almost awhile.
After a bit of work I have it working. Mostly. It would seem I can only watch or record one show.
I'm thinking that because I had a test tuner in I've fouled the whole thing up.
So, I'll be doing a full win 7 re-install tomorrow and just start from scratch. That ought to unfuck any testing I did.
These things sit on the shelves forever so they usually initiate a firmware upgrade as soon as you plug them in (which can take 30-60mins in my experience), which is why you shouldn't unplug after your boot up the first time (and restart the process). Ceton diagnostics should indicate that the process is underway.
sounds like somethings broken. I've never had issues with my hardware once it was pairedAfter trying to watch TV yesterday I think I've hd enough. It had two random hissy fits for no reason, and the recording I tried to watch got screwed up halfway through because the CC magically decided I had no subscription.
So since I can return everything and only be out the $50 for the cable install, I think I'll wash my hands of this PITA.
All I really want to do is watch TV!
I just came into my office to shut the pc down and it wanted to setup the cablecard, again.
Yeah, I'm done this little project.
edit: CC was hot when I took it out. Guess I'll keep fucking with this.
Not sure if you're referring to the Ceton, but cablecards can also be somewhat flakeyTook four reboots to get the card to come fully up. I'd say I have a flakey card.
You can also find Linksys DMA2100/2200, HP x280n which work pretty well too (though they are discontinued).
They work with Windows 7 Media Center?
I just use Sickbeard and Sabnzbd. Everything we want is automatically recorded, organized, and is completely commercial free. And we pay $0 per month.
hey, thats great buddy. good for you.
Must have rained on your parade or something.
