Go L624A E6600, go!
GoldenTiger
I Got It Back... Kinda
http://valid.x86-secret.com/show_oc.php?id=116699
This is my OC thus far... P5W 1101 BIOS. E6600 CPU week L624A... 3600mhz even at 9x400, 1:1 ratio, about 1.485v actual voltage. I'm happy as heck with this so far... it is game-stable, NOT prime-stable/SuperPi yet, retail stepping B2 chip. I will update with further truly stable results.
doormat said:
What cooling? Water? Air?
Air cooling with a Zalman CNPS8000 in a modded mATX X-QPack case that can now take ATX boards :D.
I couldn't prime for more than about an hour at 3.6, and I didn't want to put more voltage into it so... I dropped it to 3.5 (389x9) and it works flawlessly, however :D!
EDIT: Going to try a few motherboard setting tweaks I read about, I will post back!
3.5 is still really good. Be sure to fill out the info needed for the Conroe OC DB.
I can do 3.6 too.. but Orthos explodes almost instantly...
You're braver than I am.
-JWM
