In the market for a glossy 27" IPS monitor for PC. Not many new options available currently, except the LG 5k which is expensive and not plug and play for PC.
Requirements
27" IPS
1440+ resolution
Glossy (not semi glossy)
Any help appreciated.
I disagree. My old Korean glossy monitor looks better than any current monitor in it's size. And I've personally tinkered with at least a dozen of them. Nothing makes an image crystal clear like a glossy glass monitor.Listen man, I was die hard on glossy displays and used a Dell S-series monitor for years because it had a glass panel, and when I switched to a modern matte display I never looked back. Even in a light controlled room there are reflections, and I didn't realize how much it was compromising the image until I actually switched. Modern AG coating is nothing like it was back in the day, I am very sensitive to it and started using glossy monitors because I could see the "crystals" sparkling on light backgrounds, but even I don't notice it all on new monitors. You'll be a lot happier if you just drop that requirement.
Strongly disagree. My 16 year old glossy NEC LCD display has subjectively better IQ than my "modern" AG coated display. Indeed, the AG coating does not block all reflections, but it also makes the colors somewhat dull and overall image does not "pop" as much. If anything, the overall image looks a bit fuzzy. Even my glossy 27" Korean-based display IQ subjectively looks better. It's even more of a joke at night, where there are zero reflections to battle with.Listen man, I was die hard on glossy displays and used a Dell S-series monitor for years because it had a glass panel, and when I switched to a modern matte display I never looked back. Even in a light controlled room there are reflections, and I didn't realize how much it was compromising the image until I actually switched. Modern AG coating is nothing like it was back in the day, I am very sensitive to it and started using glossy monitors because I could see the "crystals" sparkling on light backgrounds, but even I don't notice it all on new monitors. You'll be a lot happier if you just drop that requirement.
Sound like you got a bad glossy sample or experience with a bad apple. *shrugg*
If you had picked any other modern feature other than the AG coating (i.e. G-Sync/Freesync, overdrive, better response times, higher refresh, improved sRGB reproduction, etc.) , then I would agree with you. But you are practically defending the least favorable feature of a modern display, imho.
I do have light in the room. It was simple for me to control ALL reflections at night. All light sources are either directly above or behind the displays. What little remains is just what light bounces off (white t-shirt, etc.).There's nothing favorable about reflections, and you will still see them at night if you have any light in the room, which you should if you care about your eyes. I'm not sure where you got the idea I had a bad monitor, the Dell I had looked great aside from the reflections, which I got used to until I switched and realized how glad I was that they were gone. Technology has moved on.
And it is not the deal breaker you are making it out to be.
I may have exaggerated when I said there are "zero" reflections at night. But obviously, I'm not bothered by what little I have to deal with. YMMV applies.Well, people can decide that for themselves I guess. That was my experience with it as the owner of one for over six years.
