I have a few s775 chips.
Model 520 (2.8/800/1mb) $10 shipped
Model 531 (3.0/800/1mb) $15 shipped
gwarren007 said:This is the one you want:
intel Btx motherboard
http://www.geeks.com/details.asp?invtid=D955XCS-PB&cat=MBB
add a backplate
http://3btech.net/tha2btxupkit.html
I can't run my new GTX275 24/7 either because it's too noisy.
If possible, putting a slow 120mm fan at the back of the computer / side near the back would help lower the temps, and then you could lower the gpu fanspeen in rivatuner.
Time for a new case then.
Okay, then grab a hole saw and make some new fan mounts. Or just settle for something inexpensive. Regardless of the quality of the case, cooling is a big problem with older cases, and it might be worth switching to a cheap case with better airflow if only for that reason.
can't you just keep the side open and tie wrap a fan?Hey, I'm running opterons and i7 with AM2 heatsinks, show some ghetto mod love!
The noise may come from the 80mm fans too, they are noisy for the air they push.
Like others said, you might want to consider another case if budget permits, the Antec 300 sometimes goes for $50 shipped, comes with a 250mm fan and 2x120mm fans (space for 2 more). You end up with a cooler, quieter system.
