I have no idea what that even means.anyone comment on Tom's review saying all gigabyte boards are running hotter then anything else because of voltage locks they are imposing on the boards.
killer NIC post such low test scores compared to intel.
The Killer NIC is decent hardware. The drivers are pretty solid in Windows 10. Back when we were still testing with Windows 7 the drivers were horrendous. I still don't like the Killer Network manager but you can do a driver only installation for them. I'd still prefer an Intel NIC or at least two NICs of identical models / brands in case I wish to do teaming. I'd also prefer an Intel NIC if I'm doing to do anything with server OSes and virtualization. I don't know if there are drivers for Windows 2012 R2 for the Killer NIC. In the past those adapters were not supported all that well outside of whatever the current version of Windows used by the mainstream public at the time.
I will be running Windows 10 on this system so would you go for the cheaper board (£60 difference) if you didn't need the intel NIC for anything special such as the things you mentioned? I'd rather get the cheaper and better looking board to save that much money if the NIC quality isn't an issue. I don't need the extra features of the Gaming 7 over the K5.
If you don't need the Intel NIC the K5 is fine.
my earlier question might have been missed.
Any stability issues with this board?
I don't know. I haven't reviewed the K5.
Sorry I wasn't clear. I meant the board you reviewed. The gaming 7.
I did not experience any stability issues with the Z270X Gaming 7. If I had experienced stability issues, I would have mentioned it in the review.
I'm very curious to see some tests for AM4 & Rysen vs Z270 & KabyLake to see which system makes the best use of the new NVMe SSD's.
i thought i saw you guys do a review of samsung NVMEI don't have a 950/960 Pro on hand. I can try it on the Corsair MP500 or an Intel SSD 750 via a U.2 to M.2 adapter.
if you got 750 NVMe slot vs u.2 in PCH that would work
....do you not talk and communicate? The other guy can't mail you one?I'm not the storage guy. We don't actually share equipment or space. I have my own test equipment separate from what the other guys have.
......that seems silly.
so does that mean you can test to see if there is a latency difference that affects performance?I get the equipment i need to do my testing when I ask for it. I do not need that specific drive. I do not need even that specific drive to do that particular test and get meaningful data out of it.
the gaming 7 showed up on amazon, had 10% off, so purchased that, and off ebay got the 7700k on ebay for 314. should be ready to rock and role next week.
Just wondering if I should upgrade my sandisk plus SSD from sata to m.2?
Nice, thanks for the review, [H]
I've been eyeballing the Gigabyte MoBo's equipped with the SoundCore 3D for quite some time...seems to be a far superior onboard solution to every other one on the market. I'll probably be getting one for my next major system upgrade, whatever that will be and whenever it happens.
Careful of the SoundCore 3D. I bought this board as well since the reviews were promising but ran into the same issue as a lot of other folks with this audio on older hardware:
Doesn't happen all the time.. maybe once a week, but sure as hell is annoying when you have a new build that doesn't work 'smooth'.
probably not but then he cant do what hes trying to force the system to do. better question would be has he followed MS's suggestions for getting THEIR universal asio drivers to work...
The youtube video wasn't mine.. just an example of what I experience. That video is from like 2015 and from google searching around has affected z170 MBs with soundcore 3d chips since. My z270 is like a month old... I'm using the latest drivers from Gigabytes website. So no.. not 'forcing' the system to do anything.
To be honest, I haven't spent a whole lot of time on it.. my system is pretty base.. no special drivers, no overclock, no special hardware other than maybe the ram which is the new g.skill ddr4 3600 cl16 tritan z rgb modules.
well when you don't make it clear that that's not YOUR vid....
so what exactly is YOUR issue then? have you tried the creative driver instead of the Gb one. I know the board just came out but they never keep the drivers up to date like the component makers do.
I've never run into issues like that with any of the GIGABYTE motherboards that integrate some form of Creative Labs sound card.
Super long thread about the issue here:
http://www.overclock.net/t/1593375/...orted-sounds-post-here-if-you-have-this-issue
Lots of people seem to have the issue with Gigabyte MBs using soundblaster chips and Gigabyte support folks are also on the thread. They've asked many of the users to send in their boards, but they have been unable to reproduce the issue, so they are now asking folks if they would be willing to send their full systems in. At one point it seemed like it might have been related to a conflict with Nvidia HD audio drivers, but doesn't seem to be the case as AMD users also have the same issue. Also, kind of a hard issue to reproduce on demand.. you can go sometimes 3+ weeks without seeing the issue, then all of a sudden it will occur again.
Pretty sure not everyone is affected by this, but seems to be rampant enough to be of concern especially if you were looking at this board in particular for it's soundcore 3d chip.
Best stay far a away from Creative SB Core3D build on the motherboard as Creative Lab has been going down hill right after the X-FiI built a new system with this board back in January. In the first 2 months, I had the sound issue once. Then it started happening every 2 weeks or so and then every other day. Needless to say, the board is out of my system and going back to Gigabyte. Just great, the main reason I picked the board over the Asus ROG Maximus IX Hero was for the SB core.
But Dan you barely use them for what few weeks at most during the reviews and get toss a sideThose have worked pretty well for me during the reviews. While I can understand where you are coming from, I have yet to have a bad experience with the Creative ZXRi or Recon 3Di built into the GIGABYTE boards.
Don't get me wrong I love Creative Labs stuff which I been using scene late 80's but ever scene MS drop hardware DirectSound Hardware-Acceleration they have gone down hill after that in my book
But there always hope now that VR and Audio need make a come back give it a more realistic sound
